4 members (JeffA, dt235sd, klhansen, UtahYork), 62 guests, and 3 robots.
Topics128,180
Posts1,057,160
Members48,464
Page 1 of 2 1 2
#1540433 03/15/2024 5:57 PM
Comteplating purchase of this old Chevy truck that’s did assembled. Supposedly all they’re just not assembled and they tell me it’s a 1927 but it has a 6 cylinder. Engine is locked. Thought those didn’t come out till 29 or so. Cab appears good. All I’ve seen of this truck is what’s pictured. Rest is located at another location.
Authorized Pest
Authorized Pest
Wrenchman. We have a '27 1-ton that is a 4-banger. Your cab looks a little like ours. That story is a little here and there but HERE IS one thread in the Project Journals area.
There are a few who can tell you much more. Stay tuned. smile
~ Peggy M
1949 Chevrolet 3804
"Success comes in 'cans' ..."
Thanks for the reply, that was a nice read!!
Authorized Pest
Authorized Pest
HERE IS some more reading. Here's where John got the cab on. Has some other images of hardware in that thread. laalaa
~ Peggy M
1949 Chevrolet 3804
Moderated
Moderated
That looks like a GMC front wheel... Not Chev!
1954 Chevrolet 3600
1930 Chevrolet Coupe
1928 Chevrolet Cabriolet
1928 Chevrolet LO 1 ton
1927 Chevrolet pickup
1925 Chevrolet Touring
1918 Chevrolet 490 Touring
I see what you mean since you mentioned it. Looked at some pics and looks like the Chevy has more spokes and are wooden. Trying to learn since I'm new at this.
Authorized Pest
Authorized Pest
Wrenchman, You might be interested in THIS THREAD tucked in Making a Stovebolt Bed. It's from another '27 guy. In there, you'll find Termite_Delight's 1928 Chevy. Oh heck. I copied it here. pix
Checking with the Modertor to see if that who thread should move into Early Trucks.
~ Peggy M
1949 Chevrolet 3804
24601
24601
John here. Judging *only* by my own truck and limited experience ... I don't think that's a '27 Chevy 1-ton we're looking at. I agree that it could be a GMC of a slightly newer vintage. Again, not sure, but that engine block doesn't look to me like the Chevy 194 (1stGen Stovebolt 6)... but I could be wrong.
The cab looks like the wider all-wood cab. Interesting (to me, anyway) seat details. VERY helpful for me.
What might be your intention for this truck? Original or something modified?
As you read, Peggy and I have taken on a project like that ... A lot of parts, some duplicates, some that don't even go to a truck ...
Just know that you have gotten into a "Long Game" ... wink
Welcome to the club!!
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
24601
24601
Also ... Here's what the front part of the frame looks like on Peggy's '27. Yours looks significantly different and more rugged -- again, suggesting a GMC rather than a Chevrolet. And bigger than a 1-ton.
Frame details on a '27
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
The cylinder casting that BOLTS to the crankcase definitely rules out Chevy. Coincidentally, GMCs all the way up to the big 503 cubic inch from the mid-1950s had that same design. GMC was built to be rebuilt, repeatedly. Chevy was sort of a "one and done" production- - - -with limited overhaul capability.
There are some 1920s Buick engines that were OHV 6 cylinder, with a cylinder that bolted to crankcase like that. Hard to say without a closer pic if that’s what you have.
I don’t know what engines were used in super early, heavy duty, GMC. They did use some engines from other lines in their first couple versions of half ton trucks….flatheads from Olds and Pontiac.
1951 3100
Found more parts to the old truck. Owner confirmed it’s a 27 GMC according to the title. Owner had doors completely rebuilt by a wood craftsman.
Wrenchman, Just in case it may help in confirming the ID of your truck, check out this article I came across this morning Gary's 1927 GMC Firetruck. There are some pictures in there that seem to confirm your radiator surround and wheels look to match with his truck. It also talks to a Buick I-6 power plant which may be what your truck has???
~ Dan
1951 Chevy 3 window 3100
Wrenchman, do you have a cylinder head for the engine? I am presuming it has to be an OHV arrangement from the look of the block.
If one goes searching for pics of 1920s inline 6 cylinder engines, you can find a small handful that have cylinders which bolt to the crankcase. However, nearly all of them were flatheads. The Buick might have been the only OHV, removable cylinder, arrangement that I could find. There might be others, that’s just all I could find that reasonably resembled yours.
I thought maybe you had something even more oddball like: Diamond T, REO, or such. None of those theories turned up anything quite like what you have there. Given GDad’s lead, I think I’d chase the Buick engine theory until you disprove it.
Side note - I’m sure some good documentation of these large trucks from that era exists. But I suspect the “vintage” of the dudes, means that more of it is on paper than on the interwebs. Finding just the right guy(s) with specific knowledge of that specific truck, is gonna be a huge help.
1951 3100
The article Dan linked about the old fire truck references a book called “The First Century of GMC Trucks.”
https://www.motorologist.com/wp-content/uploads/GMC_Truck_History-century.pdf
I’m not sure if this is the whole thing, but you’ll start seeing references to the Buick engines starting in the section on the 1925 trucks. Looks like they used them for several years thereafter.
1951 3100
Great article!!
Authorized Pest
Authorized Pest
That did look like a good info piece. However, when I went down to his footnotes, and linked on the first one, something spazed my computer and locked it up. Never a good thing.
I was hoping to add the PDF in his post. So, I guess the link will have to do it. Maybe it won't affect others computer.
~ Peggy M
1949 Chevrolet 3804
Looking at the pictures of the block deck, it seems like there are big crescent shaped cutouts, like the deck is part of the combustion chamber shape and the pistons don't come all the way up. Is that what's really happening? I've never seen an engine like that, and I've laid eyes on a few old timers in my day.
Still looking for the cylinder head! AND other parts. This old guy has parts scattered over several buildings.
Authorized Pest
Authorized Pest
Wrenchman, why not post in Truck Parts Wanted in the Swap Meet. Worth a try...
~ Peggy M
1949 Chevrolet 3804
John M mentioned “long game” in his post. His project has that feel in a much more common (relatively speaking) truck.
Unsolicited free advice: You’re going to have to make some decisions around goals for your project:
1) Keeping the drivetrain absolutely correct - I’d consider this a very, very long game. Unless you stumble across the missing engine parts and they just miraculously work as-is.
2) Keeping drivetrain “sort of” correct - that article suggests GMC was using variants of the Buick six up until at least 1930. This would open up some more possibilities, but still likely take a long time to piece together a working drivetrain.
3) Just get it on the road/ going “modern” - “Modern” in your case might mean a GMC six from the 1940s or 1950s. Would take some adaptation, but you can probably find a running version on FB marketplace in just a few weeks if searching. They are scarce, but they exist.
There are no wrong answers. It’s your truck. Looks like the wood portions of the cab and the chassis are a great starting point, regardless which way you decide to go.
I’ll be following along. Cool project.
1951 3100
Sorry I worded that poorly. I meant I was still looking thru buildings and barns that current owner has looking for parts for the 27 since truck was complete when he purchased it. All the parts are in his possession just trying to dig through a lot of “Stuff”.
24601
24601
Wrenchman, I have a feel for what you are going through. I'm still trying to get my project sorted out. They are puzzles and when you get them already disassembled ... Its a challenge just determining if you actually have all the pieces, let alone how they go back together.
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
Check out the engine pictures in this 1927 Buick Master Six ad- - - - -looks like a pretty close match.1927 Buick Master
Last edited by Peggy M; 03/23/2024 10:48 PM. Reason: fixed the link. Great truck! :D
Thanks for posting a link to that article. After seeing the info tag on the engine in the article I pulled up a pic of the engine in the truck. And can now almost clearly see the Buick name on it. Before I thought it read “Burb” but instead it reads”Buick”! Now to just locate the head and other parts.
If you don't find it, try putting a want ad in Hemming's Motor News. Now that you know which engine you're looking for, there's bound to be a collector out there somewhere with some spare parts available. You might even find a complete engine in running shape.
Wrenchman, Below is screenshot from an out of stock 1927 GMC T40-T50 advertisement that has a very detailed illustration of the Buick I6. From what I've read, that engine for the larger trucks was the 274ci model, while the engine used in the T20 1 Ton is noted to have the 207ci Buick I6 (from Gary's 1927 Fire Truck article in my reply above).
There are some 1927 Buick engine pictures in this AACA thread that may be helpful in the future.
Also came across this original 1927 Buick manual that may be of interest and could provide some additional info on your engine too. Best of luck on locating all the parts and pieces of the truck! thumbs_up
~ Dan
Is that the generator that bolts up to the back side of the timing cover? If so….is it gear driven?
1951 3100
It looks like the generator, the water pump, and possibly the distributor share a common drive- - - -most likely off the timing gear for the camshaft.
So weird, and cool.
If you look at the ad Dan posted, it speaks of a “ventilated crankcase.” Looks to me like the rear end of that same drive is operating some sort of air pump or such that is pulling vapors from crankcase. Pulling it straight out to atmosphere.
1951 3100
That's the water pump. I've worked on a few industrial engines that do the same thing, as well as Nash inline sixes from the early 1950s.
Weird!
1951 3100
Well I ended up making the deal and purchasing the truck and brought it home this evening. Ended up finding the head but still missing the manifolds and carb . We’ll see what happens. Anyone have Buick Standard engine or parts lying around as we have made a determination that it came from the factory with a Buick standard overhead valve 6 cylinder engine.
Started by taking a look at the steering column as the throttle and spark levers were frozen. Freed up those two levers and thought I’d change the steering gear box fluid. Any idea on what type fluid to put back in. Didn’t get hardly any out and it was black and nasty. Can’t find a repair manuals for it either or I wouldn’t be asking the question.
The trick lube most stovebolters use on steering boxes is John Deere "corn head grease". It's about the consistency of honey, so it flows well enough to lubricate, but it's too thick to seep out of some pretty sloppy clearances found on older steering boxes.
Thanks, that was my first choice but thought you more experienced guys might have another choice of lube instead.
Any idea thoughts on where to purchase some shop/repair manuals?
24601
24601
Wrenchman,
There are some early vehicle parts vendors out there, and between Rustoholic and I we can probably put together a list for you. Pretty iffy if they will have anything for you but who knows?
As you are discovering, the restoration process on these ... more mature ... vehicles is a long game. The actual wrench turning is the easy part. Finding information is pretty hard .... and finding parts ... well, that's what turns this game from "Go Fish" into three dimensional chess.
I doubt *anyone* is reprinting the manual for that truck. Check ebay and all the other usual on-line suspects.
While you do that, also go over to our old friend Keith Hardy's excellent site for old vehicle manuals.
If this were easy, everyone would be doing it.
smile
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
Thanks for the reference and yes it could’ve a long wait on finding parts. Takes a lot of patience.
Wrenchman, Here are a couple of possible resource books I found (all Buick that coincides with your engine) that may be of some use at least in that department. smile
Reproduction 1927 Buick Shop manual w/1928 Supplement
1927 Buick Book of Parts - Series 115
1927 Buick Book of Parts - Series 120 & 128
I also stumbled across this Antique Engine forum that had a thread with several pictures of 1928 GMC T20 restoration work that might have some useful info too. headscratch
~ Dan
Page 1 of 2 1 2
Moderated by  John Milliman
