0 members (), 35 guests, and 3 robots.
Topics128,014
Posts1,055,327
Members48,419
#1553822 07/28/2024 12:02 AM
Hello, I have a 235 engine and have three different numbers I'm trying to decipher:
Pass side by starter- CON4 K187
Pass side below dist- 3738307 (I found this which says its a 58-62 235)
Stamped on flat next to distributor- FII2IJ (FYI- these are stamped with the capital I, not the number 1, so it appears the only number is 2?)
CON K(11th month-November) , 18th day, 7th year of decade/1957? Doesn't make sense as 3738307 shows to be a 58-62 block?
I'm confused. Thanks for the help
1959 Chev Napco 4x4 3100 w/235cu
F = Flint Assembly Plant
1121= Nov 21
J = (1958)31-32-36-3800 Thriftmaster 235 with 3 speed.
The 1958 were introduced in October of 57.
Thank you Jimgmc,
that makes sense. Appreciate it.
CON is the conveyor (assembly line) that the engine was made on.
1950 Chevrolet 3100 (Ol' Roy)
Copy Otto, thank you
K 18 7 is November 18, 1957
Thanks Bill
