5 members (Forty9, Wally / Montana, TooMany2count, MaxStewart, 50Chevy3100), 82 guests, and 0 robots.
Topics128,108
Posts1,056,566
Members48,448
TKM
Offline
Converted my 1949 3600 to 12V a few years ago and kept the 6V starter. Unfortunately, the 6V starter is on its last legs intend to replace it with a 12V starter. Any recommendations on a source for a 12 volt?
A 6v starter can be used with a 12v system without any problems.. Just don't hold the key for long time if it doesn't start in a few seconds.
Switching to a 12v starter will require a new flywheel since 6v and 12v starters have different gearing.
Have the old starter rebuilt. There are a lot of qualified rebuilders. I'm sure there is an old time auto electric place up there in Detroit that can rebuild your old one.
If not, call Then and Now Automotive. www.then-now.com
1950 Chevrolet 3100 (Ol' Roy)
I had funny noises in my 6 volt starter years ago and solved them like this.
Still working well on 12 volts now.
Insomniac
Insomniac
As suggested, get the 6V one rebuilt. I had my 6V starter rebuilt and it didn't cost much. Nice to support a local business.
Gord 🇨🇦
1954 1/2 ton 235 4 speed
A six volt starter will turn the engine over faster than a 12 volt starter believe it or not. If the bearings and brushes are in good shape, they work fine last long time.
I drove my 3100 all the way across a level parking lot with the key off. I mashed the stomp starter, let the clutch out gingerly in first gear and off I went. I couldn't go fast enough to shift into second before I ran out of parking lot. Starter survived just fine.
TKM
Offline
Thanks everybody! Didn’t realize the fly wheel would have to be changed also. I will look for a rebuilder in my area. What would I do without stovebolt.
If there's nobody local, NAPA can get a rebuilt starter with a good warranty overnight in most areas. Just be sure to specify 6 volt. (1954 or earlier) There's a difference in the angle of the pinion teeth and the diameter of the armature shaft from the 12 volt units. The 6V has a shaft about 5/8" in diameter, while the 12V models are close to 1/2". If the original ID tag is still there, 12V starters have a red tag. 6V ID tags are black.
Yes. I bought a brand new a starter from NAPA for $79 last December. I kept the original 1949 one because I thought it was worth more than the $19 core charge. Maybe I'll rebuild it someday.
