4 members (elhippie64, Leo, Otto Skorzeny, Gone), 60 guests, and 4 robots.
Topics128,180
Posts1,057,157
Members48,464
Going to be installing a new oil pan gasket kit due to my old one is starting to mark its territory a little too much and wonder if everyone is still using the FelPro -OS 5153C for their 235. Mine is a '62.
Cheers
Craig
I've used Fel-pro (no part no's, sorry) and prefer the rubber end pieces of the gasket set for the newer(?), not straight sided pan. My late '55 235 pan is straight sided but that set has the cork end pieces which are a booger for me to install. So I bought both kits. In the past for my 216 I always used cork ends and it always leaked. Now thanks to the rubber end pieces that flare on each side to provide more overlap of the side pieces, ZERO leaks. So for me, it's idiot proof. grin
Matthew 6:33
1952 Chevy 1/2-ton 3100
Late '55 235/SM420/torque tube 3.55
Dalton Highway survivor (using original 216)
www.truckwithaheart.com
Moderator, Electrical Bay
I've used both with equal success. I used to think the rubber ones were better. I'm not sure anymore.
~ Jon
Thanks for the replies. When you say rubber end pieces, as shown here?
This is the Felpro OS 5153 C, which I was planning on using again.
Craig
I believe that is the set I used .
Six years and 5,300 miles later, not a drop of oil leaking from oil pan!
Todd
1950 Chevy 3100
Yep that looks like the end pieces I used.
Matthew 6:33
