5 members (Otto Skorzeny, Bill Hanlon, Shaffer's1950, KEVINSKI, 1 invisible), 327 guests, and 0 robots.
Topics128,101
Posts1,056,180
Members48,436
#155343 10/12/2007 3:03 PM
i am rebuilding the brakes on my 46 new lines hoses
shoes the works. the master is pitted and the booster needs a complete overhaul. should i swap in a master booster duel unit frame mounted if so what
would make a good doner. i am not interested in a
hydro power steering unit. thanks
#155344 10/13/2007 1:15 AM
Sounds like a good idea.
I would lean toward a bracket that mounts the assembly to the frame with a longish push rod going back to it from the pedals.
I like a hydroboost, but you should be fine with a vacuum booster, I just don't know which one would be best for you.
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
#155345 10/13/2007 2:25 AM
Apprentice
Apprentice
I have just started to work on the brakes on my 46 2 ton as well.I have all the same problems you have and was also thinking about a different booster and master.There is a company close to you in Mooresville called master power brakes that have good tech support and a lot of good product.An aftermarket 9'' dual diaphram booster and m.c. for a mid 70's pickup may work O.K. They will get you fixed up there, but I don't know how hard it will be to get wheel cylinders sorted out. Keep us posted. Jim
