2 members (rick46ia, Hotrod Lincoln), 72 guests, and 4 robots.
Topics128,022
Posts1,055,352
Members48,420
#1553395 07/22/2024 5:55 PM
Is it necessary to install a 235 as it sits in the frame? Or can I install it level for run test?
Red wave
1950 Model 3104 5-Window
"Back In Time"
Follow in the DITY
O Online: Content
Level is fine. Engine in truck drives up and down hills all the time and doesn't care how it's oriented.
1950 Chevrolet 3100 (Ol' Roy)
Thank you
"Back In Time"
Follow in the DITY
To be a stickler, it should sit at the same angle as when installed in the truck. The carburetor will be level then, and float level won't be affected. But there really isn't much change unless you're climbing a 60% grade.
