| | | Forums66 Topics128,050 Posts1,055,671 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2023 Posts: 239 'Bolter | | 'Bolter Joined: Jun 2023 Posts: 239 | Is it necessary to install a 235 as it sits in the frame? Or can I install it level for run test? Red  | | | | | Joined: Oct 2021 Posts: 6,739 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,739 | Level is fine. Engine in truck drives up and down hills all the time and doesn't care how it's oriented.
1950 Chevrolet 3100 (Ol' Roy)
| | | | | Joined: Jun 2023 Posts: 239 'Bolter | | 'Bolter Joined: Jun 2023 Posts: 239 | | | | | | Joined: May 2015 Posts: 11,029 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,029 | To be a stickler, it should sit at the same angle as when installed in the truck. The carburetor will be level then, and float level won't be affected. But there really isn't much change unless you're climbing a 60% grade.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | |
