3 members (Gdads51, UtahYork, 1 invisible), 109 guests, and 3 robots.
Topics128,191
Posts1,057,364
Members48,469
Is this weatherstripping supposed to be glued in place? Putting in new glass and found it as you see.
1956 3100 three speed 6 cyl. Stock with a few upgrades.
Moderator, Electrical Bay
It has been a while since I did a 1956 but as I recall there were a couple of small screws that held it in place. Wasn't glued as I recall. Please look where the strip would fit in the upper part of the door and see if you see any small holes.
~ Jon
Jon I just went out and looked. There are two screw holes up forward but they mount the vent window frame. Nothing else there. What made me ask was becaues I watched a you-tube video and the guy used a black adhesive.
That black adhesive (which is actually just black contact adhesive and I think 3M makes the best) could be used. Just follow the instructions...
~ Jon
Well it's done now. Thanks Jon. BTW to the rest of you, if you've installed the vent window and you're having a really hard time pulling the side window up to install it, check to see if you set it down in the door backwards. 🙃
Thanks Mickey. That has happened to me also. Good information to have/use!
~ Jon
Moderated by  ndkid275, Phak1
