0 members (),
196
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,081 Posts1,056,078 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2013 Posts: 224 'Bolter | | 'Bolter Joined: Dec 2013 Posts: 224 | My ‘47 3100 AD finally has its new cluster gauge installed and wired correctly thanks to the helpful suggestions here. The problem remained that the ammeter was still always charging! Something was still wrong!
Went back and fully charged the battery and checked it for load and draw when running. Battery ok. Next the generator was checked for output, draw with lights/no lights. Appeared normal. To reassure my self I had it bench tested. Was ok. After I mentioned the next step, the voltage regulator, the technician said he needed the generator and VR together for the test. Next day he tested both and said the VR was the problem. So I’ve ordered a new VR- not cheap but obviously necessary. Hopefully the malfunctioning VR was causing my ammeter to always show Charge. Hope I didn’t fry the ammeter in the process!
I’m reading here but can’t find an answer to: “ will I have to polarize the VR or is it a simple install and connect the generator and VR?” I am not the sharpest knife in the drawer with elect. stuffing. | | | | | Joined: Oct 2021 Posts: 6,791 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,791 | You polarize the generator via the regulator.
Briefly jump the BAT and ARM terminals on the regulator to polarize the genny. It takes about a millisecond and you'll see a little spark. Both units will then be "in sync."
1950 Chevrolet 3100 (Ol' Roy)
| | | | | Joined: Feb 2004 Posts: 29,795 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,795 | There are two kinds of voltage regulators- - - -Delco-Remy, and "WRONG"! If you're buying a new regulator, you're taking a huge gamble. A lot of them are bad right out of the box, due to the fact they're made in some offshore sweatshop by virtual slave labor. The quality control is just about nonexistent. There are plenty of serviceable "pre-owned" Delco units on Ebay. The prices aren't outrageous, either. A little primer and paint will make them look brand new. Then all you'll need to do is find someone who knows how to adjust it to get the proper output from the generator. The adjustments are:
Closing voltage Current regulator Voltage regulator
The adjustments are made by changing the spring tension on each of the three sets of magnetic points under the cover. The voltage regulator needs to be adjusted when the generator is charging against a fully charged battery. On a 6V system, the setting needs to be 7.5 V, on a 12V it's 14.5V. Adjustments tend to reduce a little when the cover is installed, due to better magnetic conduction of the stamped steel. Jerry
| | | | | Joined: Dec 2013 Posts: 224 'Bolter | | 'Bolter Joined: Dec 2013 Posts: 224 | Wow…..you speak with tons of knowledge and experience. Me hardly none. Actually did look on eBay at used units. Looked at Jim Carter’s catalog and called, asked if they were USA made and made by Delco. They said yes. Asked if the cover was stamped Delco. No. Does that mean it isn’t a as is not labeled? I thought Jim Carter was a reliable source of quality parts……although I recognize many vendors handle the same imported stuff. As many here have written. Since I’ve ordered it, I will examine it carefully before I do anything. Might be an idea to send a picture and let it be evaluated. | | | | | Joined: Feb 2004 Posts: 29,795 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,795 | 6 volt or 12 volt? I have both types stashed away, original equipment stuff that's still in working condition. Did your spark chaser say why your regulator was "bad"- - - -and did he make any attempt to fix or adjust it? I'm guessing probably not. Send me a PM so I won't get a nastygram from a moderator- - - -click on my username and select the PM option. I might be able to repair and adjust the one you already have. Delco-Remy went out of business 30 years ago. The stuff labeled "Delco" or "AC-Delco" is an offshore knockoff, regardless of their "Made in USA" claims. Most likely the BOX is printed here- - - -not necessarily what's inside! Jerry
| | | | | Joined: May 2015 Posts: 11,065 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,065 | If you're reasonably handy and careful, there's a procedure for adjusting the voltage regulator in the service manual. Unless you can't screw a nut on a bolt, you can probably do it.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Oct 2021 Posts: 6,791 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,791 | I'm betting that the regulator sold by Jim carter is made by Regitar. They are stamped as made in USA but what does that mean these days? It is not a digital/electronic VR but an actual old style unit with springs and points. Is it made to the original Delco Remy standards? Nothing these days is made to any standard that one would have expected 75, 50 or even 40 years ago.
Buy it, install it and if it works, Great! Don't ever discard original parts, however, because you will probably end up needing to rebuild them sometime in the future.
I have a Regitar in my Cadillac and AD truck. So far, so good. Neither came from Jim Carter.
| | | | | Joined: Feb 2004 Posts: 29,795 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,795 | Here's a new Delco-Remy 6V negative ground regulator, 35 amp. There are other, used ones on Ebay for considerably less. www.ebay.com/itm/335298607897?Jerry
