0 members (),
70
Mod | | | Forums66 Topics128,179 Posts1,057,159 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2021 Posts: 42 'Bolter | | 'Bolter Joined: May 2021 Posts: 42 | Rebuilding a 1950 3100 stock. My window crank on the drivers (left) side will not roll up all the way. It would not close up at the top right curve on the window. Replaced with another crank/regulator and it was even worse. It would stop about an inch from being completely up. Notice the right roller arm which holds the track that the window mounts to was bent a little downward so straighten and even tried to add a little bend the opposite and that helped slightly. Totally lost at this time. Any suggestions?
BTW if I'm on the wrong page for posting this someone please direct me where to go.
1950 Chevy 3100 PU all stock
| | | | | Joined: Sep 2009 Posts: 6,015 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 6,015 | Curtis Lee - Your door window question will get the best on topic replies and help in the Doors forum in the “Paint and Body Shop”, so it’s been moved there for further conversation and help. Other Bolters should be along soon to offer some help.
~ Dan 1951 Chevy 3 window 3100Follow this story in the DITY Gallery"My Grandpa Carl's Truck and How it Became Mine"1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
| | | | | Joined: May 2021 Posts: 42 'Bolter | | 'Bolter Joined: May 2021 Posts: 42 | Believe I got it fix. Made the adjustment holes that are slotted a little longer by elongating them at the top. This is where the "elbow" of the riser app rotates on a three-point mount. I enlarged the holes for the crank app and raised it slightly. When placing the window (framed) on its mounting track I pried it up while tightening the screws giving me a little more lift. But there is little one can do for the wear and tear of a 70-year-old mechanism, but I did peen the rivets on the joints tightening them a little.
Hopes this helps someone. Thanks
