1 members (baldeagle), 35 guests, and 4 robots.
Topics128,014
Posts1,055,327
Members48,419
#1552339 07/11/2024 12:02 PM
Is it possible to remove the stomp switch on the starter and replace it with an electric switch? This is only temporary while the engine is on the test run stand.
Red
1950 Model 3104 5-Window
"Back In Time"
Follow in the DITY
Shade Baby #1552351 07/11/2024 1:48 PM
Probably easier to temporarily replace the starter with a solenoid operated starter. There is a LOT of current flowing through the stomp switch.
Shade Baby #1552427 07/12/2024 1:53 AM
There are no parts inside of a stomp starter to engage the Bendix with the flywheel.
52Carl #1552431 07/12/2024 2:29 AM
Just to clarify what you said Carl, the stomp starter engages the Bendix with a lever connected to the pedal (the same one that pushes the button on the starter switch.)
But you are correct, you can't just hook up a solenoid switch to a stomp starter and expect the Bendix to engage the starter.
Red, if you have the engine on a test stand, it's easy enough to push the lever on the stomp starter to start the engine.
Shade Baby #1552433 07/12/2024 2:43 AM
.. I should have said get a '54 Chevy solenoid starter.
Shade Baby #1552448 07/12/2024 9:03 AM
Ok and thank you Red
"Back In Time"
Follow in the DITY
