| | | Forums66 Topics128,035 Posts1,055,566 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2023 Posts: 236 'Bolter | | 'Bolter Joined: Jun 2023 Posts: 236 | Is it possible to remove the stomp switch on the starter and replace it with an electric switch? This is only temporary while the engine is on the test run stand. Red
| | | | | Joined: Jan 2022 Posts: 2,442 'Bolter | | 'Bolter Joined: Jan 2022 Posts: 2,442 | Probably easier to temporarily replace the starter with a solenoid operated starter. There is a LOT of current flowing through the stomp switch.
'57 GMC 102, Original 347 V8, HydraMatic, 3.08 rear gear, added A/C, disk front brakes, HEI, AFB carb, '98 Honda Black Currant paint. T-boned and totaled 10/12 '52 GMC 152 Stake Bed, Original 228, SM420, added A/C, HEI, disk front brakes, '67 Chev 3.55 rear gear. Gets used as a real truck.
| | | | | Joined: Mar 2010 Posts: 10,272 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,272 | There are no parts inside of a stomp starter to engage the Bendix with the flywheel.
| | | | | Joined: May 2015 Posts: 11,024 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,024 | There are no parts inside of a stomp starter to engage the Bendix with the flywheel. Just to clarify what you said Carl, the stomp starter engages the Bendix with a lever connected to the pedal (the same one that pushes the button on the starter switch.) But you are correct, you can't just hook up a solenoid switch to a stomp starter and expect the Bendix to engage the starter. Red, if you have the engine on a test stand, it's easy enough to push the lever on the stomp starter to start the engine.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Jan 2022 Posts: 2,442 'Bolter | | 'Bolter Joined: Jan 2022 Posts: 2,442 | .. I should have said get a '54 Chevy solenoid starter.
| | | | | Joined: Jun 2023 Posts: 236 'Bolter | | 'Bolter Joined: Jun 2023 Posts: 236 | Ok and thank you Red
