3 members (JW51, UtahYork, Wickedbass), 61 guests, and 2 robots.
Topics128,066
Posts1,055,876
Members48,428
Bought a new gauge from Dynacorn and trying to find how to make it fit. The bulb has a connection larger than 1/2”. The original hole is a 1/2”. The bulb for the gauge fits in the hole but covers the thread.
Where can I get an adapter or what size?
Thanks. Daniel
Daniel
1949 Chevrolet 3600
That is a fairly cold location on the block and is usually the home of a drain petcock. I'd look for a mounting spot on the head or below the thermostat in the thermostat housing.
Here's the stock location on a 216. Your sensing bulb should fit right there.
Thanks! I do have that spot. I missed it.
Daniel
1949 Chevrolet 3600
