5 members (Denny Graham, Steelonsteel, 66flea, treegrower, Otto Skorzeny), 52 guests, and 1 robot.
Topics128,076
Posts1,055,924
Members48,430
#1550871 06/27/2024 11:52 PM
does anyone know what the CCs are of a large port 302 head with the D shape combustion chamber??
THANKS Jay D.
jay d #1550872 06/27/2024 11:56 PM
B Online: Content
I measured mine once to get an idea of what the static compression ratio would be. I'll see if I can find the numbers somewhere. If not, I'll measure again in a few days.
Mine were 118cc. 104cc after removing .080 of the head. Also shaved the block .020 To bring the pistons level to the block. Never calculated compression ratio.
just retired and finally making headway on my project truck. 1940 GMC AC152.
jay d #1550883 06/28/2024 2:35 AM
B Online: Content
Using GMC-IS-ME's 118cc (7.2 cubic inches), a stock 4" bore piston that comes all the way to the deck and a 0.060" thick head gasket with a 4.060" hole the static compression ratio computes at 7.3:1
jay d #1550891 06/28/2024 4:32 AM
Thanks, just what i needed!!!!
Jay D.
jay d #1552024 07/08/2024 6:24 PM
>060" gasket means .060" quench, much too loose. You want .035-.040"
