| | | Forums66 Topics128,110 Posts1,056,251 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2018 Posts: 1,004 'Bolter | | 'Bolter Joined: Aug 2018 Posts: 1,004 | The bumper will not be strong enough It will work But your bumper mounts will be deformed afterwards Anyone who says otherwise did not do the following
On a concrete floor Measure your bumper ends from ground Now jack up one side of the truck on the end of the bumper as if to replace a front tire Keep it jacked up for 15-30 minutes Lower the truck Measure both side again and compare to previous measurements Enjoy your new custom bent crooked bumper mounts
Also bad Do not pull or push the vehicle with the bumper They look much tougher than they actually are My grandpas 51 has 1/2 a bumper when it snapped through a mounting bolt hole when being pulled out of a ditch -s | | | | | Joined: Oct 2010 Posts: 44 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 44 | Thanks 2 many I just thought I would ask before I spend money on a high lift jack
| | | | | Joined: Feb 2004 Posts: 29,803 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,803 | Untold thousands of wheels have been changed with bumper jacks- - - - - -and a lot of bumpers got bent in the process. A scissors jack or a hydraulic bottle jack under an axle housing or a spring is a lot safer and less likely to do damage. Here's some inexpensive insurance to avoid damaging anything: www.harborfreight.com/automotive/ja...oor-jack-with-rapid-pump-blue-56642.htmlJerry
| | | | | Joined: Nov 2004 Posts: 2,409 Former Workshop Owner | | Former Workshop Owner Joined: Nov 2004 Posts: 2,409 | If you place the jack under the frame horn it should be fine. I lifted my ‘59 Viking 40 several times with that same jack. Just be careful and use jack stands for safety.
As mentioned above, there are better jacks to use.
~ J Lucas 2006 GMC Envoy 4.2 I6 2023 Ram 2500/Cumins 6.7 I6 2010 Jeep Grand Cherokee (Wife’s) 2002 Silverado 2500 Gas 6.0 1941 Chevy 1/2-Ton 1942 Chevy 1.5-Ton SWBIn the Gallery My Flicker Photos! | | | | | Joined: Feb 2004 Posts: 29,803 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,803 | About the only thing my high lift jack really does well is stretching barbed wire when we're building fences, or maybe changing tractor tires. We use big wood blocks to crib up the tractor as soon as the tire is lifted just high enough to unbolt the lugs. Jerry
| | | | | Joined: Jul 2000 Posts: 2,193 Insomniac | | Insomniac Joined: Jul 2000 Posts: 2,193 | Don't know if that's an original Jackall.
I have a Jackall that I carried in my 1980 C20.
One day, I had the truck stuck in a creek bed. The rear end slid sideways and the diff was stuck with the wheels in the ruts. Used the Jackall to lift the rear end by the step bumper. Pushed the rear end over so the wheels were out of the ruts. We were miles from nowhere and no cell phones back then.
I also used it to change tires. No issues with the bumpers being bent, but it seems they were stronger back then. I would not use it on my 2010 truck.
Gord 🇨🇦 ---- 1954 1/2 ton 235 4 speed | | | | | Joined: Jul 2018 Posts: 270 'Bolter | | 'Bolter Joined: Jul 2018 Posts: 270 | Well, these jacks are a subject I’ve long had an opinion on. You can lift a lot of weight quickly. Very useful, in the right hands. And yes, you can lift, tip over the jack to move one end of a vehicle over sideways. I had one with a big 10 inch plate welded on the bottom and it was a bit more stable, etc. BUT. I always insist on anybody I work with: never jack without BOTH hands on the jack.One on the top. Gives you some control and feel for when it gets tippy. But mainly it keeps you safe from getting bonked in the head, and some warning to get out of the way if it’s going down. Which all illustrates that they are plain dangerous in the wrong hands. The High Lift version with the removable handle is the worst. Do ask me how I know!😆 And it goes without saying, so to speak, don’t do the trick where you let go while jacking down and it Jig-A-Jigs itself down! I use mine a lot😁
~Charley 1954 Chevy 3100 with 235“Bud”Follow along in the DITY1963 Chevy half ton stepside short box 230 1954 GMC 3 ton 302 And several more Chevy camper and work trucks 1979 1987 1996 | | |
