3 members (Otto Skorzeny, Ponchogl, hardshell), 43 guests, and 1 robot.
Topics128,024
Posts1,055,392
Members48,422
#1551530 07/04/2024 5:31 PM
Onto the next wiring hurdle after building my new dash wiring and taping up into its own harness.
I have no brake lights. I have markers.
I have power to brake switch and power out of the switch.
Bulb tests good. Ground at socket is good.
No power to the new rear wiring. Will test shortly but I bet I have no power to the firewall connection.
Does brake power run through the steering wheel connector? I have not gotten to that yet.
1966 C-10 Step Side
"Augustus"
Engage in the DITY
or follow along in his
Project Journal
The brake out of the pedal switch goes to the turn switch to send the signal to left, right or both depending on turn switch direction.
Is this an aftermarket harness...different that stock?
Chip
'Rusto-Mod'
'51 Chevy 3600 5 window | C4 Corvette front/rear suspension & drivetrain | everything else looks old and stock
'92 GMC Sonoma GT #15 of 806
'91 GMC Sonoma GT Extended cab 1 of 1
Trucks, Trucks.....and more Trucks
That's what I was wondering when I started working my way to the firewall.
Something is not right under my steering wheel. I can't have the plug, plugged in aa there is a draw. I guess I might have to figure that out now.
1966 C-10 Step Side
"Augustus"
Engage in the DITY
Project Journal
Attached is a generic drawing of how a late '50s and early '60s GM turn signal switch works. Wiring colors are correct for my '57 GMC. Ignore the colors for anything else. The top drawing is with the turn signals off. The center is signaling a right turn. The bottom is signaling a left turn.
Ferris: I had a constant draw through my steering column when I first hooked it up a couple weeks ago and the left brake light never came on.
I sprayed electical contact cleaner in the switch contacts and just worked the turn signal stalk back and forth for a couple minutes and it cleaned up.
You might try the same. It is a cheap/easy fix if it works.
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Task Force Truck
Follow in the DITY Gallery
1959 3200 Task Force
The Ballad of Enkidu
Morning,
Currently the guts of my blinker assembly is sitting on my work bench cause I couldn't figure it out a few months ago. This is in conjunction with a gap I have between the wheel and the collar I can't get rid of, a top bearing that won't stay in place, etc.
I might have not cut the shaft short enough when I was installing the new steering box, but who knows at this point. I guess this weekend I will rip the wheel off and try to figure out what is happening in there.
1966 C-10 Step Side
"Augustus"
Engage in the DITY
Project Journal
