7 members (Woodcmiami, cmayna, Hotrod Lincoln, Gdads51, mick53, MickeyP, 1 invisible), 34 guests, and 10 robots.
Topics128,012
Posts1,055,312
Members48,419
#1550362 06/23/2024 3:44 AM
What is the go to steering column to update a 65 truck? 73-87 I read but is there a specific year or vehicle to use the column from?
Chevron #1550373 06/23/2024 12:40 PM
Socket Breaker
Socket Breaker
Uhm... ya want a straight column? Ya want a tilt column? Automatic shift / manual shift on the column? Ya running a shifter on the floor?
A lot of folks have used various ones out of the squarebodys.
There was an early 1970s chevy van that had a tilt column as well, but from what I have been told most of those have long since been stripped or scrapped.
my '65 c10 has a 1971 ish straight non tilt steering column for automatic shift.
you can see photos of it, here:
pics of my truck
If you want aftermarket, there is a company called: ididit that makes all sorts of fancy steering columns.
https://www.ididit.com/
Chevron #1551160 07/01/2024 11:28 AM
RLB Offline
I have the Ididit in my 66 c10. Somehow I ended up with. 67 thru 72 unit. I had it over a year before I realized the mistake. Too late to send it back. It turned out to not be a big deal, install was very easy. Even the American Autowire retire kit plugged right in. Mine is tilt plus has the 4 way built in. It was non painted & for floor shift model. Very pleased with it. I used a Grant 15” steering wheel, happy with that too
1966 C-10 Short Stepside
HiPo
Step-by-step ~ and on-going resto build
in the Project Journals
Chevron #1554370 08/02/2024 4:48 PM
Rebuild the original.
Here’s a 4 part DIY.
Remove. Disassemble. Rebuild. Install.
https://lugnutz65chevystepside.weebly.com/steering-column-page.html
