0 members (), 106 guests, and 0 robots.
Topics128,101
Posts1,056,181
Members48,436
#1550991 06/29/2024 6:11 PM
I picked up a replacement engine for my 216, it was in a 56 GMC 1/2 ton truck the seller didn't know if it was original or was replaced at some time.
Block casting # 3836340 Light Blue color.
Serial # on the lower block # W 23 206 and close to the distributor # 34784
Head casting # 3836848
Looking through the info online and on here it looks like it's a 261 with a higher compression head.
What I would like to know is if my research is correct.
Thanks for any information anyone can provide.
1950 Chevrolet model 1434 5-Window Canadian manufactured 1-Ton with Dump Bed / Hoist
You will never stop learning new things, no matter how old you are.
Being in Canada I'd say it's a Pontiac 261, I believe they used the 848 head.
BC
1960 C60 pasture art
doyle1950, I think you have it pegged as a Canadian 261. Lots of info in a couple of previous threads on this engine Engine Code starting with "W" and Canadian 'Poncho' Rebuild.
The same block casting number 3836340 was used on both US and Canadian 261 from 1955-62 as referenced in Bolter tclederman's Stovebolt Casting Numbers webpage and many other resources.
Sounds like your truck is in for a big step up in the powertrain! grin
~ Dan
1951 Chevy 3 window 3100
I have 1957 and 1959 261 engines from Canadian GMC trucks both stamped serial numbers start with a "W". The "M" inside the raised square on the right side of the engine indicates it was cast in Canada by McKinnon industries and the captains bar indicate a 261 engine. Solid lifters its a truck, hydraulic lifters for a Pontiac.
1954 Chevy 1300 engine 235 (1959)
1955 (first series) Chevy 3100 engine 261 (1957)
1927 (other brand) Model T- engine 327 (1968)
