Long story, but after getting hosed by a local trans shop, I found the correct replacement for the output shaft of my PTO. Its a 51 , one ton with the Muncie sm420. If you have to replace your seal like I did because it leaks, here ya go. TIMKEN # 470162, direct replacement for VICTOR 49347
