3 members (J Lucas, tclederman, Southerntruck), 72 guests, and 1 robot.
Topics128,133
Posts1,056,398
Members48,441
#15504 04/23/2003 4:48 PM
after work tomorrow, i plan to remove a hydraulic 235 clutch and bellhousing from a '61 truck at the local u-pull it. the complete drivetrain is still in the truck. i'm not too sure how to proceed, since the yard wont let you bring in any jacks or power tools. when removing the 194 from my '31, i had a lot of difficulty splitting the bellhousing from the engine, as several of the bellhousing bolts were blocked by the clutch. is the 235 bellhousing set up the same way (ie, are any of the bolts head only accessible through the inside of the bellhouing)? should i remove the engine or try to seperate the bellhouing with the engine still in the truck? any suggestions?
thanks,
ed
Yes, there are four bellhousing bolts behind the flywheel. Removal of the engine is required to get the bellhousing free, since it supports the engine. That could be tough without a hoist. Once you get the flywheel off the bellhousing unbolts pretty easily.
Paint & Body Shop moderator
Be careful when you pull it. I was standing in an engine compartment pulling an 848 head when the front of the truck fell about a foot. That made me think.
this truck has an 848 head... if i already have 2, is it worth pulling?
ed
See if the yard guys will pull the engine and tranny for you, after you undo as much as you can. Take what you need, and leave the 848 head for the next 'bolter. If you're feeling really nice, cover the motor with something so it doesn't rust shut before the next guy gets to it.
But yeah, you'll have to pull tranny and flywheel to get to all the bellhousing bolts.
good luck
chip
Preaching the Hot Rod Gospel according to the 4-stroke apostles:
Suck, Squish, Fire and Fumes
