4 members (Hotrod Lincoln, Guitplayer, LAROKE, 1 invisible), 54 guests, and 3 robots.
Topics128,154
Posts1,056,840
Members48,456
#1549781 06/17/2024 12:38 AM
Moderated
Moderated
Hello, I’m doing a shop clean up this summer and came across this on the shelf. I haven’t had an older Chevy in quite a few years, and don’t even remember where I picked this up or what for.
Can anyone identify year, make or models it would work in. I’m sure someone out there would like to have it for a resto, or gut it. Looks like a plain jane AM radio.
Jeff
JJF20 #1549798 06/17/2024 4:34 AM
Are there vacuum tubes inside the radio? GM had some hybrid radios in the late 50s & early 60s that were tube type, except for the output stage which used Delco either DS-501 or DS-503 germanium transistors. Most used 10 ohm speakers and were VERY sensitive to speaker impedance. Easy to let the smoke out.
I think the very early GM all-transistor radios also used the same germanium transistors.
If I was going to guess, I'd say Corvair bezel on the front.
JJF20 #1549813 06/17/2024 2:44 PM
2 Offline
Looks to me like OP photo above is 1960-61 Corvair radio
Delco 988062
The 1962 model has Delco written on the face in small script.
Image of the 62 below
-s
JJF20 #1549816 06/17/2024 3:12 PM
I would have to agree with Bill on the "Corvair" identity. A little research through 1960-69 original Chevrolet ads and dealer info pamphlets showed your pictured manually tuned AM radio as being offered as an optional accessory for all Corvair (passenger car) and Corvair 95 (what Chevy called "Trucks" at the time) from 1960-65. A couple of sample screenshots are below. In 1966 they offered newer/redesigned radios and this style went away. Somewhere on the metal case is probably a part number and possibly a date manufactured stamped to pinpoint what you have.
~ Dan
1951 Chevy 3 window 3100
JJF20 #1549858 06/17/2024 6:31 PM
Moderated
Moderated
Thank you guys. Best I could figure yesterday was Corvair as well. No stampings or marks anywhere I could see. I don’t want to open it up either.
At least I can pass around I have one that is probably out of a corvair.
If anyone is doing a restoration on an corvair and looking for an original radio, let me know. Not looking to make off it, be nice to see it back in its original position.
JJF20 #1549859 06/17/2024 6:50 PM
Jeff
If you're looking to sell it, maybe post it on a Corvair related forum, or at least a Chevy car forum, like the Vintage Chevrolet Club of America.
We're all about GM trucks here on Stovebolt. Glad the guys could help you out ID'ing that radio. thumbs_up
Moderated by  truckernix
