4 members (FAST55, 50Chevy3100, Otto Skorzeny, 1 invisible), 79 guests, and 3 robots.
Topics128,050
Posts1,055,758
#1547397 05/18/2024 10:51 PM
Just bought this set. Notice this set has a deeper throat than most.
I’ll make a stand with foot pedals so I can work with 2 hands.
It has allowed me to shrink the flange on the 18ga rocker patch panel pictured. The vertical portion was bowed due to the curve at the bottom but shrinking the flange pulled it flat again. The curved 90° bend was made with a bead roller.
Shrinker-Stretchers are neat tools. I used one at a buddy's shop to fabricate a replacement for a rusted out seat riser flange where it welds to the floor. Worked perfectly.
You are collecting all the cool toys.
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Task Force Truck
Follow in the DITY Gallery
1959 3200 Task Force
The Ballad of Enkidu
This video shows the pedal operated stand for my shrinker/stretcher combo. It took 6X longer to make than I anticipated. The pivot for the pedal arm is a 1/2”-13 bolt and captured nuts welded in place. The arm rotates about 20° during use so the bolt simply threads and unthreads less than 1/4 turn and is easily replaced if it gets worn.
Pedal operated stand for shrinker/stretcher
Looks great!
Moderated by  MNSmith
