1 members (SandraD), 56 guests, and 5 robots.
Topics128,021
Posts1,055,355
Members48,420
#1549719 06/16/2024 4:07 AM
I am looking for a drag link replacement . I'm converting to power steering on a 1939 Chevy 1.5 ton truck , I have the steering box and arm with a tie rod end .
I am looking for a way to replace the ball with a tie rod end at the front wheel . the distance from steering arm to the front wheel mount is 12 inches . if I drill and press out
the ball , what type of tie rod end would I need to replace this ? is a swedge tube strong enough for this idea ? what is recommended ?
thanks for looking
manymiles #1549783 06/17/2024 1:06 AM
7
7 Offline
I found an adjustable drag link with the correct taper on each end for my '57 2 ton, ordered it from Summit Racing. I don't have any experience with the older trucks so it's up to you to research the type of end needed.
manymiles #1549825 06/17/2024 4:11 PM
Moderator, Electrical Bay
The main thing is to find tie rod ends that can connect correctly to your pitman arm and steering control arm. Some are straight (no taper) and some are tapered. The tie rod ends need to match the design of what they're going into. If you use a tie rod end some may hold up better than others in this application. I had a MOOG part that completely failed when I did this so I converted back to the stock type drag link. Good luck.
~ Jon
manymiles #1549845 06/17/2024 5:08 PM
I struggled to find a reliable and usable source for ball joint taper specs….when taking on a similar endeavor.
If anyone has such a link or resource to share, might be worth posting for the greater good
1951 3100
manymiles #1549847 06/17/2024 5:17 PM
MOOG used to provide this and a lot of other useful information when using their online "part finder" but I wasn't able to find it a few months ago when a friend asked me. I'm sure they still have the information, but production and some other aspects of this company have been turned over to 16 different countries including China, Turkey, Thailand, Mexico and others.
~ Jon
