5 members (Forty9, 3B, TPR57C, Otto Skorzeny, DennisM), 123 guests, and 3 robots.
Topics128,026
Posts1,055,403
Members48,422
#1549615 06/15/2024 11:25 AM
1 Offline
When using a test meter on a positive ground system, in this case 12 volt, do you touch the red lead to chassis (ground)and black lead to item being tested? Does it matter?
Thanks for your input.
Pedals 3
Paddles 0
7
7 Offline
Red test lead will always go on whatever the positive battery cable goes to, in your case it will go to the chassis. If you reverse the test leads it won't cause any harm, the meter will just read in negative voltage, unless you are using an analog meter in which case it might peg the meter at the zero end and you could end up with a calibration issue.
1 Offline
I thought so but wasnt sure, thats why I asked. I knew the answer would be here.
Pedals 3
Paddles 0
