| | | Forums66 Topics128,193 Posts1,057,246 Members48,466 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2022 Posts: 87 'Bolter | | 'Bolter Joined: Dec 2022 Posts: 87 | When using a test meter on a positive ground system, in this case 12 volt, do you touch the red lead to chassis (ground)and black lead to item being tested? Does it matter?
Thanks for your input.
Pedals 3 Paddles 0
| | | | | Joined: Feb 2016 Posts: 1,995 'Bolter | | 'Bolter Joined: Feb 2016 Posts: 1,995 | Red test lead will always go on whatever the positive battery cable goes to, in your case it will go to the chassis. If you reverse the test leads it won't cause any harm, the meter will just read in negative voltage, unless you are using an analog meter in which case it might peg the meter at the zero end and you could end up with a calibration issue.
| | | | | Joined: Dec 2022 Posts: 87 'Bolter | | 'Bolter Joined: Dec 2022 Posts: 87 | I thought so but wasnt sure, thats why I asked. I knew the answer would be here. Thanks
Pedals 3 Paddles 0
