2 members (Ole49GMC, Hush), 74 guests, and 3 robots.
Topics128,169
Posts1,057,102
Members48,463
#1549257 06/11/2024 12:42 AM
Howdy! I have a 1954 3100, 3 speed, torque tube driveline. For sundry reasons I would like to convert to the SM420 transmission, which was an option originally for that truck. Herein lies my question: if I find a tranny made post 1955 for an open driveline truck, can it still be made to work with my torque tube rear? I have heard that the tailhousing from my 3 speed (the piece that bolts to the driveline) is interchangeable with the SM420; does anyone have the experience to say this is true?
Thanks!
-Curtis
They are not the same, you need the SM420 Bearing Retainer with casting number 591679 to convert a newer open drive shaft trans to the 1954 and back closed dive shaft.
There are a couple on ePay now, just search "591679 bearing retainer".
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Awesome, thanks for the info!
Not close to you but I do have a 4 speed I removed from my '50 3600 that has a torque tube back end (the 3600 had an eclosed front drive shaft and an open rear drive shaft). I can not atest to the transmissions condition as it was removed early in my restoration. PM me if you are interested.
1949/50 3600 Project
Follow in Project Journals
H Online: Content
The hard to find part for that conversion is the universal joint. They're very scarce, and usually expensive if you manage to locate one for sale.
Why make it hard? there should be plenty of torque tube sm420's out there. I support the KISS theory. LOL I guess my question is, why? the only gain is a granny, unless you are using your AD as a farm/work truck.
Larry
Old man᠁Old truck᠁neither one goes very fast. All you need in life is TIME, PATIENCE and MONEY.
If you are missing one component, you'll need an abundance of the others two.
