3 members (Hush, dt235sd, 1 invisible), 164 guests, and 0 robots.
Topics128,080
Posts1,056,060
Members48,433
#1549104 06/08/2024 10:24 PM
Crusing in the Passing Lane
Does anyone know the included angle on lug nuts, .625” NF, slightly less than 90 degrees on some new nuts in hand. Need to make a new wheel torque plate. I can measure existing, I thought someone might know? Thanks.
Ed Pruss
Speedway (and other places I looked) say that 90° and 60° are the normal angles:
Speedway Lug Nuts
I see a number of places that indicate that 60° is the most common, but 90° shows up on some vehicles.
That is assuming you are looking at modern wheels/nuts. If you are trying to find info on originals, this info is probably not super useful.
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Task Force Truck
Follow in the DITY Gallery
1959 3200 Task Force
The Ballad of Enkidu
I grabbed a couple of lug nuts I have laying around (one from my '51 AD, and another that was from a more modern car I had) and both were 60 degree. I checked them with a square and they were definitely not 90 degree.
Thanks, guys.
Ed Pruss
