Is there a place a guy can buy the shoulder bolts that attach the top part of the seat to the bottom piece for a 55.2 to 59 Chevy/GMC seat?? Thanks for any help.
As one who depended on his 3 point belt to do the right thing in my '57 GMC, I would not use the seat as an attachment point for the belts.
My shoulder mounting points had a piece of 1 1/2" by 8" of 3/16" flat steel bent to match the curve of the inside of the cab with a 1/2" hole in the center with a welded on nut for the belt pivot.
The lower outside mounting points had a 4"x4" square plate on the outside underneath of the foot well of the cab entrance.
I don't have a picture of the center belt attachment. It was one 4"x12" piece of 1/4" steel with a 1/2" hole drilled near each end for the short center belts.
Tested the system in October of 2012. I ended up hanging upside down in the belt with a scratch on my elbow and needing to change my underwear.
'57 GMC 102, Original 347 V8, HydraMatic, 3.08 rear gear, added A/C, disk front brakes, HEI, AFB carb, '98 Honda Black Currant paint. T-boned and totaled 10/12 '52 GMC 152 Stake Bed, Original 228, SM420, added A/C, HEI, disk front brakes, '67 Chev 3.55 rear gear. Gets used as a real truck.
niobrarafun, if you have a good old fashioned hardware store or possibly ACE hardware, look in the specialty fasteners drawers, most will have shoulder bolts.
I'm sorry. I read "shoulder BELT", not "shoulder BOLT". Bad case of [censored] on my part.
If your local hardware store doesn't have them, McMaster-Carr has them. LINK
Kevin 1951 Chevy 3100 work truck Follow this saga in Project Journal Photos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together.
Mr. G's Enterprises 5613 Elliot Reeder Road Fort Worth, Texas 76117-6013 817-831-3501 or 817-838-3131 https://mrgusa.com/
1950 Chevrolet 3100 (Ol' Roy)
Ebay has shoulder bolts of all sizes listed. I use them for specialty projects that require a precision fit pivot bolt pretty frequently. Jerry
