6 members (Charles in CA, lumbersawyer, Rustnut, Hotrod Lincoln, Donf, 1 invisible), 64 guests, and 4 robots.
Topics128,203
Posts1,057,414
Members48,471
Is there a place a guy can buy the shoulder bolts that attach the top part of the seat to the bottom piece for a 55.2 to 59 Chevy/GMC seat?? Thanks for any help.
1956 Chevy 3100 Stepside Shortbox
More pix on Photobucket
As one who depended on his 3 point belt to do the right thing in my '57 GMC, I would not use the seat as an attachment point for the belts.
My shoulder mounting points had a piece of 1 1/2" by 8" of 3/16" flat steel bent to match the curve of the inside of the cab with a 1/2" hole in the center with a welded on nut for the belt pivot.
The lower outside mounting points had a 4"x4" square plate on the outside underneath of the foot well of the cab entrance.
I don't have a picture of the center belt attachment. It was one 4"x12" piece of 1/4" steel with a 1/2" hole drilled near each end for the short center belts.
Tested the system in October of 2012. I ended up hanging upside down in the belt with a scratch on my elbow and needing to change my underwear.
7
7 Offline
niobrarafun, if you have a good old fashioned hardware store or possibly ACE hardware, look in the specialty fasteners drawers, most will have shoulder bolts.
I'm sorry. I read "shoulder BELT", not "shoulder BOLT". Bad case of [censored] on my part.
If your local hardware store doesn't have them, McMaster-Carr has them. LINK
Automotive fasteners, of all types
Mr. G's Enterprises
5613 Elliot Reeder Road
Fort Worth, Texas 76117-6013
817-831-3501 or 817-838-3131
https://mrgusa.com/
1950 Chevrolet 3100 (Ol' Roy)
H Online: Content
Ebay has shoulder bolts of all sizes listed. I use them for specialty projects that require a precision fit pivot bolt pretty frequently.
Moderated by  ndkid275, Phak1
