0 members (), 110 guests, and 1 robot.
Topics128,196
Posts1,057,394
Members48,471
Looking for some help. pulled rear drum off and brakes were wet with oil or grease, has new brake cylinder as of 9 months ago didn't see any brake fluid and master is full. is it rear axle seal ? and how to fix. Thanks for any help
1955 second series 3200
Mike, It most likely is a failed seal, although it could be your vent is blocked which can over-pressurize the axle and force lube out the seals. Either way if it's leaking now then it needs to be replaced. Take a little time and read through Section 4 of the 1955 2nd Series Truck Shop Manual (free access to everyone). I believe the info you need to start with is on Pg 4-5. You will have too remove the axle to replace the seal. BTW - Since you are having to pull the axle anyways, now is a good time to check the bearings and condition of the differential since you must open that up to remove the axles. wink
~ Dan
1951 Chevy 3 window 3100
Check both axles for a wear groove where they ride on the bearings. A failed seal is quite often the result of axle and/or bearing wear that lets the axle bounce up and down on the seal as the wheel hits bumps in the road.
