5 members (Youngin' Tut 59, 52Carl, Bill Hanlon, UtahYork, Peggy M), 181 guests, and 0 robots.
Topics128,190
Posts1,057,339
Members48,469
I am trying to help a friend assemble their windshield. Unfortunately, I did not take photos of the parts or this process during the reassembly of my ‘46. It appears they might be missing a piece, but I’m uncertain. I am helping them remotely, as they live several hundred miles away. I searched the bolt for previous posts without finding the info needed.
Could someone post or PM me photos showing the center divider bar parts including the outer stainless steel strip, gaskets, brackets etc? Of particular interest is the SS strip and the nested piece that bolts to the inside the windshield rubber gasket and metal painted strip. Please.
Thank you.
Lee
Lee, I don't have personal first hand pics to share, but have included pics I took of details from a 1942-47 Passenger Car / 1942-46 Truck Shop Manual Windshield instructions (pics 1-2) and from a 1929-46 Chevy Master Parts book showing the lower windshield to dash area details (pic 3) which may provide some help with your friends reassembly. Hope it gives you at least a start to what he needs. wink
~ Dan
1951 Chevy 3 window 3100
Dan
Thank you for helping and the info.
The picture needed would show the back side of the stainless steel outer trim. Apparently they are unable to get the screws to securely fasten all the pieces together. I can’t recall if there were some king of nuts or a separate flat strip of metal with threaded holes or some other option?
Lee, Maybe the info and details in this early Pre-War Truck Tech Tip about windshield rubber replacement may be helpful. There is info on how to disassemble/reassemble a 1940 GMC truck windshield that may be similar for the 1941-46 trucks???
This paragraph may have a helpful point:
"First, I removed the windshield connector and top and bottom tee connectors. Next, I removed screws that hold the inner and outer center division bars (the longer screws go on the top and bottom of the center bar) and carefully removed the outer bar with care as to not to destroy the rubber seal that is part of the center bar."
~ Dan
Lee, Another possibly helpful bit of info may be found in this Filling Station ad for their Reproduction Division Bar. If you click on the technical part drawing it show details that may help answer the question.
~ Dan
Dan
Thank you! I think this info will answer the question at hand!
Dan:
I speak for myself only, but I am sure others will agree, the service and helpful info you research and provide is very much appreciated.
A tip of the hat and a frosty🍺 to ya!
Cheers,
Lee
Thanks for the very kind words Lee! thumbs_up I love the hunt/search for knowledge almost as much as sharing it. grin Just glad I can offer something back to the community that has provided me such great support and a place to be a Stovebolter! chug
~ Dan
