5 members (Forty9, 3B, TPR57C, Otto Skorzeny, DennisM), 123 guests, and 3 robots.
Topics128,026
Posts1,055,403
Members48,422
#154821 09/14/2007 1:10 AM
Hello, Purchased new tubes for the tires I'm putting on my 4400. They have a flat piece of steel with a slight bend on each end of them and also a nut. They obviously fit over the stem and then the nut threads on. It appears they must go on the inside of the rim, there is not enough thread to mount them on the outside. Is it critical they be used? Are they for all types of rims? It seems they could cause problems with the tube. (mine are stock 1954 rims)Thank you, Scott
1954 Chevrolet 4400 1.5-Ton Dump Truck
1946 Chevy 1.5-Ton Dump Truck
1944 Chevrolet 1.5 Ton Dump Truck
1955 4400 Dump Truck
1951 2 Ton Stake Body
#154822 09/14/2007 1:22 AM
After mounting untold hundreds of such tube/rim combinations, I can assure you the metal plate is intended to go OUTSIDE the rim, with the nut holding it in place. If the rim is too thick, just discard the plate and nut. It's not there to keep the stem airtight in the tube, or anything like that.
