| | | Forums66 Topics128,077 Posts1,056,032 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2012 Posts: 240 'Bolter | | 'Bolter Joined: Mar 2012 Posts: 240 | Hello All,
I am rebuilding a s 3 speed top-loader transmission from a 1947 3100. While making the necessary repairs and parts replacements, I'd like to renew the synchronizers (1st to 2nd was starting to require double clutching, so it's apparent they're worn).
I'm having difficulty with spreading the retaining rings that hold the cones in place. Has anyone found a trick to spreading these to get the cones out?
Thanks for any advice.
1947 3100 Advanced Design
Never, never, never, never give up. - Churchill | | | | | Joined: Apr 2005 Posts: 2,097 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,097 | I have used snap ring pliers with the removable tips which are thin enough to get in the slot. The replacement brass rings are available at several aftermarket sources. However you may be wasting your time and money trying to replace them. If you look closely the brass ring is staked from the inside of the synchro drum which causes some of the brass to protrude into the small holes in the housing. That is essentially what holds the ring in place. I'm sure that there was some special tooling designed for this process. Just pressing in the rings won't hold them in place long. You may be better off trying to find a better one. Fred
| | | | | Joined: Mar 2012 Posts: 240 'Bolter | | 'Bolter Joined: Mar 2012 Posts: 240 | Fred,
Thank you for the advice, It was helpful. I agree with your concerns, the friction fit alone concerns me.
I've wondered if that staking wasn't there more for the manufacturing process (machining the brass sleeves in place) as opposed to durability? I've rebuilt my synchronizer with the aftermarket rings and will see how long they last. If there are issues, maybe there is a better staking method?
Best regards,
Never, never, never, never give up. - Churchill | | | | | Joined: Feb 2004 Posts: 29,792 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,792 | If you're replacing the rings anyway, why not use a Dremel tool with a small cutoff wheel to remove the old rings in a few pieces? Getting the new ones in should be a much easier task than removing the old ones. Making some sort of staking tool with a pair of vise grips and a pointed setscrew shouldn't be much of a problem- - - -similar to the tool that's used to stake the safety spring tube in place when rebuilding a 1911 .45 automatic pistol. Jerry
| | | | | Joined: Mar 2012 Posts: 240 'Bolter | | 'Bolter Joined: Mar 2012 Posts: 240 | Jerry,
I've already placed the rings (should have measured the interference, but know it's there: had to cool the rings in dry ice and heat the sleeve to about 150'F and still had to press them in). The new rings are thick such that staking from the inside doesn't seem likely (at least with the tools I have available).
However, I'm wondering if I were to undersize drill through the old staking holes and through the rings, then tap for an appropriately sized brass screw, cut it off/shape it on both sides, then stake the screw. The thought is that a brass screw would be similar strength and wear rate to the brass ring - it should hold it axially and wear along with it against the cone.
Your thoughts?
Never, never, never, never give up. - Churchill | | | | | Joined: Feb 2004 Posts: 29,792 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,792 | Sounds like a plan to me. Be sure to allow for a little rotary movement of the replacement ring, as its function is to assist the shift collar in aligning with the teeth on the reduction gear as the speeds match up. The ring isn't supposed to be rigidly attached to the synchronizer body. Jerry
| | | | | Joined: Jun 2022 Posts: 557 'Bolter | | 'Bolter Joined: Jun 2022 Posts: 557 | If you had to freeze the rings and heat the sleeve and still had to press them together.... unless you intend on working the truck thousands of miles heavy hauling then I wouldn't worry about it. Driving it like the antique it is should not be a problem. Be sure to use 90wt mineral oil. Anything else will damage the brass rings.
~~ Jethro 1954 3100Back to LifeIn the Dity Gallery1951 3100 (gone) / 1956 4400 (still in the neighborhood) / 1957 6400 with dump body (retired) / 1959 3100 panel (in the woods junked) / 1978 Custom Deluxe K10 / 1993 S-10 4.3 / 2004 Chevy Crew Cab / 1945 John Deere H / 1952 John Deere B / 1966 John Deere 2510 / 1967 John Deere 1020 | | | | | Joined: Apr 2005 Posts: 2,097 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,097 | Bill, My intent was to provide some information that was shared with me by a friend and mentor years ago. He owned and operated a transmission shop specializing in manual transmissions in the greater LA area for over 50 years. They are staked for a purpose. I have seen several synchro drums that the brass rings have pulled out or are loose. Of course many things wear out in these units by normal use. Your repair may last many years as your vehicle doesn't have a lot of horse power and is likely not a daily driver. All the best. Fred
| | | | | Joined: Feb 2010 Posts: 3 'Bolter | | 'Bolter Joined: Feb 2010 Posts: 3 | Hi Bill,
If you are interested, there is a thread on the VCCA site with the heading "41 TRANSMISSION REBUILD" that goes into detail about replacing synchros etc. I've rebuilt a few and always struggled with getting the synchro cones out using various snap ring pliers until I got a pair of Kent-Moore J-932's
Clem
1949 Deluxe Cab 3100 Pickup 1949 Deluxe 3100 Panel 1930's-1940's Kent Moore Tools
| | | | | Joined: Mar 2012 Posts: 240 'Bolter | | 'Bolter Joined: Mar 2012 Posts: 240 | Thank you all for your comments and suggestions. Looks like the VCCA rebuild article includes one post were a punch was used to stake the new rings, I thought staking would be more complicated than that. I hope to start re-assembly this week, not certain when I'll get it back in. I'll post my results. Best regards, Bill
Never, never, never, never give up. - Churchill | | | | | Joined: Apr 2004 Posts: 5,074 Authorized Pest | | Authorized Pest Joined: Apr 2004 Posts: 5,074 | Can someone give the link to that article so it can be included here, please.
~ Peggy M 1949 Chevrolet 3804"Charlie" - The Stovebolt FlagshipIn the Gallery"We make a living by what we get; we make a life by what we give." -- Winston Churchill | | | | | Joined: Mar 2012 Posts: 240 'Bolter | | 'Bolter Joined: Mar 2012 Posts: 240 | Certainly: https://vccachat.org/ubbthreads.php/topics/432347/1.html I hope others find it helpful. Thanks to Clem for pointing it out. Best regards, Bill
