8 members (HandyAndy, 52Carl, 55shaker, Cosmo, RoadsScholar, Jay R, Ponchogl, 1 invisible), 76 guests, and 0 robots.
Topics128,049
Posts1,055,629
#1548001 05/26/2024 4:30 PM
I950 Chevy 3100 has the enclosed U-joint in the "Ball" on the tail end of the transmission. How do you get the oil into this location to lubricate the joint? Please help refresh my mind.
1950 Chevy 3100 PU all stock
CLSnMO #1548003 05/26/2024 4:37 PM
Grasshopper, the answers to all life's mysteries can be found in "The Manual".
1950 Chevrolet 3100 (Ol' Roy)
CLSnMO #1548004 05/26/2024 4:46 PM
Curtis Lee, According to step "5" of the "Assembly" instructions in the Shop Manual on pg 4-52, you remove the speedo drive gear and fill the housing from there. wink
~ Dan
1951 Chevy 3 window 3100
CLSnMO #1548014 05/26/2024 7:24 PM
There's also a plug just forward of the u-joint bell on the transmission. It's a little above centerline on the right side and mainly serves to keep the output shaft bushing in place, but goes all the way through to allow you to put gear oil in it. It's angled up a bit so you could pour oil in without it running all over the place, but a suction gun with a tube on the end would be a better choice.
BTW, the page that Dan shows says "Fill the housing with transmission lubricant", but it only takes 1/2 pint. Don't overfill, although you could remove the fill plug on the side of the transmission and fill till it starts running out there. A quart is enough to fill the original 3 speed transmission in your truck. 1/2 pint for the u-joint area and the rest in the main gearcase till it runs from the fill plug on the side.
CLSnMO #1548029 05/26/2024 11:44 PM
Thank you very much Gentleman. Your reply's will again send me back to the books.
