2 members (DaveV, 1 invisible), 90 guests, and 1 robot.
Topics128,136
Posts1,056,427
Members48,441
#1547960 05/25/2024 6:32 PM
I found a NOS SKF C1506 bearing that I would like to use for my 46 1/2 ton rear differential pinion bearing. The bearing number is 2F-C1506 and was made in Sweden. Any idea what the 2F prefix means?
Larry P
Larry
46 Chevy 1/2 ton stake - family truck for 78 years
USAF 75-81
Do you have the original bearing on hand to compare with that one? I don't think I've ever seen a pinion bearing that's not tapered, unless it's being used behind the gear teeth, like on a Ford 9 inch, etc.
Yes. The original bearing was a Hyatt OR1506. The bearing sets right in front of the pinion gear. See attached pics (hope I attached them correctly). I believe it takes the radial load of the pinion gear. The 3.55 parts kits include a C1506 bearing for this that is made in China. I'm just trying to stay away from China bearings if at all possible.
Thanks.
Larry P
Larry
USAF 75-81
Hyatt OR 1506
GM part number 125630
Thanks jimgmc. I had not seen that one.
Larry
USAF 75-81
Jerry, AD 3100's use a that 1506 roller bearing just forward of the pinion teeth, and a double roller bearing (that resists thrust in two directions) at the front of the pinion shaft.
