3 members (Nick in Manitou, CuzzFuzz, Tronman), 115 guests, and 2 robots.
Topics128,080
Posts1,056,314
Members48,442
#1547612 05/21/2024 2:55 PM
Any ideas where to find the gaskets alone for the original steering box side cover?
~ BD.
1958 Apache Stepside
1958 Apache 1/2 ton Panel
1959 Apache 1/2 ton Panel
Make your own? Those look like cardboard to me.
1951 3100
Yes sir. Thats what I did.
~ BD.
Crusing in the Passing Lane
Punch sets are available designed for cutting gasket material, a lot quicker than using a ball bearing or such!
Ed
Probably quicker than my pocket knife...I`ll bet.
~ BD.
I use the ball end of a small ball peen hammer (a ball bearing works, but I end up hitting my fingers) to cut one bolt hole on a too big piece of gasket material. Then put a bolt through that hole in the gasket and into (or through) the casting, snugging the bolt to hold the gasket in place. Then cut a second bolt hole (furthest from the first bolt is best) using the same procedure. Now that the gasket is held in place use the ball end of the hammer to cut any additional holes and the flat end of the hammer head to cut the rest of the gasket.
