2 members (Ponchogl, Jon G),
365
Mod | | | Forums66 Topics128,163 Posts1,057,044 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2021 Posts: 1,258 'Bolter | | 'Bolter Joined: Nov 2021 Posts: 1,258 | 66 c10.
Assembling and mounting the bed on truck I measured and found the right rear is almost an inch lower vs left. Everything else seems straight.
I have new rear sill and center beams. I have shimmed it about 3/8 but it still measures off what I consider alot. Going to wait until I can pull out of garage and get a better look at it before I shim more.
Anyone else have to shim a bed to get it straight? | | | | | Joined: Feb 2023 Posts: 385 'Bolter | | 'Bolter Joined: Feb 2023 Posts: 385 | Yes, I had to shim my 66 short stepside about a 1/2 on the right front | | |
