10 members (JW51, Gdads51, artinva, Peggy M, VicZ, Ridgeback, RAC1812, Shaffer's1950, klhansen, 1 invisible), 122 guests, and 0 robots.
Topics128,077
Posts1,055,928
Members48,430
#1547329 05/17/2024 11:39 PM
I was having trouble with the left signal not staying down. It would pop right back up The right turn worked fine. So I took a look and things looked pretty worn and dirty so I went ahead an put it a new turn signal kit. Problem solved on the left turn staying down. BUT, now neither signal will self cancel when the turn is completed. What is it that kicks the signal back to the neutral position?
1956 3100 three speed 6 cyl. Stock with a few upgrades.
MickeyP #1547336 05/18/2024 12:12 AM
A little piece that sticks down from the steetring wheel.
MickeyP #1547339 05/18/2024 12:38 AM
Sir Searchalot
Sir Searchalot
The canceller plate.
MickeyP #1547340 05/18/2024 12:44 AM
Mickey, Since this has to do with lighting, it’s been moved to the Electrical Bay as that’s the most on-topic forum for your topic. wink
~ Dan
1951 Chevy 3 window 3100
MickeyP #1547344 05/18/2024 12:53 AM
You guys are great. I didn't even see that when I removed the old steering wheel. Thank goodness I didn't throw it away. I'll get that finished in the morning.
UPDATE installed needed piece and all is well. salute2
