8 members (TUTS 59, Bill Hanlon, GMCJammer51, NJC, Wayne67vert, 2-Ton, 2 invisible),
80
Mod | | | Forums66 Topics128,263 Posts1,058,136 Members48,482 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2019 Posts: 95 'Bolter | | 'Bolter Joined: Jul 2019 Posts: 95 | I have a question before I even start the brake bleeding process. I noticed that the bleeder screws don’t have the typical nipples to attach a bleeder hose to. Is there something that attaches to the bleeder hose itself that screws into the screw on the wheel cylinder? This is a’49 chev 3800. Thanks for any info!
1949 Chev 3800
| | | | | Joined: Aug 2010 Posts: 613 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 613 | I think you just crack it and have helper step on the pedal, then close it when fluid stops squirting out. Repeat til you stop seeing air bubbles. Don't forget to check the master cylinder fluid level periodically!
| | | | | Joined: May 2015 Posts: 11,255 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,255 | I think I'd replace the bleeders with ones having nipples on them for the hose, which should end under the level of the fluid in a catch container. That minimizes the potential for air to be sucked back in when your helper lets off on the pedal. Without a clear hose on it, it's hard to see air bubbles.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Jul 2019 Posts: 95 'Bolter | | 'Bolter Joined: Jul 2019 Posts: 95 | Thanks to all for the information!
1949 Chev 3800
| | | | | Joined: Nov 1995 Posts: 5,759 24601 | | 24601 Joined: Nov 1995 Posts: 5,759 | Rubi -- I think Tronman meant to say that you close off the bleeder just *before* it stops squirting fluid.
At anyrate, having done this more than once on my 3804 ... You *do* want to replace your bleeders with the barbed ones (to get a hose on). Not only can you prevent a mess on the shop floor and stop sucking air back into the line, you can also reuse that fluid (once the air bubbles evacuate themselves ... and the fluid is still good and not nasty).
If an assistant to pump the brake pedal for you is not available, as in my case, you may find spending about $60 on a power bleeder to be a help. I use one made by Motive Products with the adapter to fit the AD truck brake reservoir. It really makes brake bleeding easy, quick and *almost* fun.
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: Aug 2010 Posts: 613 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 613 | Good point on when to close the bleeder, to keep from inadvertently drawing any air back in. Also yeah, would be better to replace the fittings with barbed ones. Although I can say I've never reused brake fluid even if it looked OK. One of its functions is carrying minute bits of rust and rubber, and out that all goes along with fluid when you bleed it. Fluid's cheap, brake parts aren't.
| | | | | Joined: Feb 2013 Posts: 614 'Bolter | | 'Bolter Joined: Feb 2013 Posts: 614 | My trick was to get a donor master cylinder fluid cap. Drilled a hole and tapped it so a air chuck filleting would screw in. Set my compressor regulator to minimum pressure and opened the bleeder on the brake cylinder. After each cylinder, recheck fluid. Jim | | | | | Joined: Nov 2022 Posts: 11 'Bolter | | 'Bolter Joined: Nov 2022 Posts: 11 | I have put speed bleeders on my truck and made the process so much easier without an assistant. http://www.speedbleeder.com/
1953 Chevrolet 3800 Dump Truck
| | | | | Joined: Jun 2022 Posts: 559 'Bolter | | 'Bolter Joined: Jun 2022 Posts: 559 | I gravity bled each wheel in turn when I rebuilt the brakes on my 54 3100. I used a new master cylinder, new lines and wheel cylinders that I had rebuilt. Opened the left rear first and watched for fluid while I did something else. Took about 10 minutes for fluid to come out and I closed off the nipple and opened the other rear cylinder. Only took a few minutes for that one to drip. Again on the front cylinders, longer line first. Kept the reservoir full throughout the process. Had full firm pedal without any squishiness. Never did have to bleed individual cylinders and I still have full pedal and stopping power two years and 4000 miles later.
~~ Jethro 1954 3100Back to LifeIn the Dity Gallery1951 3100 (gone) / 1956 4400 (still in the neighborhood) / 1957 6400 with dump body (retired) / 1959 3100 panel (in the woods junked) / 1978 Custom Deluxe K10 / 1993 S-10 4.3 / 2004 Chevy Crew Cab / 1945 John Deere H / 1952 John Deere B / 1966 John Deere 2510 / 1967 John Deere 1020 | | | | | Joined: Jul 2014 Posts: 17 'Bolter | | 'Bolter Joined: Jul 2014 Posts: 17 | 1954 Chev 3800 flat bed, I have the best assistant, my wife she climbs into the truck with her knitting I raise her up on my lift. She knits until I am ready, I give the command push the peddle in, them release. Brake bleeding easy, and we are all happy. Richard | | | | | Joined: May 2011 Posts: 195 'Bolter | | 'Bolter Joined: May 2011 Posts: 195 | Like KP06 said, those speed bleeders are great. I used them on my 1946 3/4 ton recently and will get another set for my 1950 1 ton soon. Easy to use and no air gets pulled back into the system.
Tom | | |
