| | | Forums66 Topics128,052 Posts1,055,725 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2007 Posts: 8 New Guy | | New Guy Joined: Aug 2007 Posts: 8 | Hello all, I've got a GMC 350 grain truck but unsure of year....the tag on the door jamb says fc354 23000 I believe, anyone know what that would designate? Also, would this be a two ton? Thanks | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Welcome to the Stovebolt Page. FC354 denotes a 1949 (FC), 2-ton truck (35), with a 179" wheelbase (4). The rest of the number is the sequence number. This and loads of other info can be found at Old GMC Trucks.com | | | | | Joined: Aug 2007 Posts: 8 New Guy | | New Guy Joined: Aug 2007 Posts: 8 | Hey thanks a lot! I appreciate it, I've been reading these forums for quite some time now, but my internet access is pretty limited, so I haven't had much of a chance to sign on. Anyways, I traded a Case VAC tractor straight across for this truck, it runs and drives around...no brakes, and I smoked the clutch on the drive home, the dump seems to work well and there's not really any rust/rot-through. The tires are ok, the rears aren't real aggressive, but they hold air. I'll try to post the link to a pic of this on my girl friends myspace. Thanks again -Rob http://viewmorepics.myspace.com/ind...&albumID=950460&imageID=15066313 | | | | | Joined: Aug 2007 Posts: 42 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 42 | hey parts master your ol ladies pictures are set to private just thought i would let you know ~dave | | | | | Joined: Aug 2007 Posts: 8 New Guy | | New Guy Joined: Aug 2007 Posts: 8 | Oh yeah? would that mean you all can't view them? If so, I'll figure out what else to do... Thanks | | |
