1 members (Hotrod Lincoln), 72 guests, and 0 robots.
Topics128,049
Posts1,055,680
#154597 08/29/2007 6:57 PM
Hello all, I've got a GMC 350 grain truck but unsure of year....the tag on the door jamb says fc354 23000 I believe, anyone know what that would designate? Also, would this be a two ton? Thanks
#154598 08/29/2007 8:52 PM
Welcome to the Stovebolt Page.
FC354 denotes a 1949 (FC), 2-ton truck (35), with a 179" wheelbase (4). The rest of the number is the sequence number.
This and loads of other info can be found at Old GMC Trucks.com
#154599 09/04/2007 6:54 PM
Hey thanks a lot! I appreciate it, I've been reading these forums for quite some time now, but my internet access is pretty limited, so I haven't had much of a chance to sign on. Anyways, I traded a Case VAC tractor straight across for this truck, it runs and drives around...no brakes, and I smoked the clutch on the drive home, the dump seems to work well and there's not really any rust/rot-through. The tires are ok, the rears aren't real aggressive, but they hold air. I'll try to post the link to a pic of this on my girl friends myspace. Thanks again
-Rob
http://viewmorepics.myspace.com/ind...&albumID=950460&imageID=15066313
#154600 09/05/2007 9:10 PM
hey parts master your ol ladies pictures are set to private just thought i would let you know
~dave
#154601 09/06/2007 6:18 PM
Oh yeah? would that mean you all can't view them? If so, I'll figure out what else to do...
