3 members (Bills Auto Works, MikeE, Otto Skorzeny), 95 guests, and 2 robots.
Topics128,095
Posts1,056,067
Members48,433
Has anybody else had an engine block on a stand do an unintended quick flop while you're turning it over to install the cylinder head, or maybe do a final check on connecting rod and main bearing torque before installing the oil pan, or bolting on accessories? I have, and it can be pretty hazardous to fingers and other appendages.
I just had a brainstorm. Stewart had a very fancy, brand new engine stand at Wrenchfest, one with a gearbox and a hand crank on it so an engine can be turned to any convenient position and locked into place. Now, I'm going to wager that his checkbook needed a little CPR after that purchase! Being the dyed in the wool cheapskate that I am- - - -why not bolt or weld a surplus automatic transmission flex plate to the head of the engine stand, and do a little creative bracketing to mesh a recycled starter drive gear and a hand crank with it? A 168 tooth flywheel and a 9 tooth starter pinion gives nearly a 19:1 mechanical advantage over that heavy engine, especially if it's turned with a hand crank about 10 or 12 inches long!
Comments, suggestions, modifications, etc. from the peanut gallery are cordially invited!
7
7 Offline
When I had a 6.5 Detroit Deisel on the stand, I used a long bar between the stand-off legs at the rear of the engine, pretty good control and the ability to lock the bar against the floor.
Maybe an old boat trailer winch would do the trick, although they basically ratchet in one direction at a time. Pretty good gear reduction, so if you keep control of the crank, it might work OK. The one on my boat trailer is double reduction.
If somebody has enough common sense to keep his fingers out of the ring gear/pinion junction, a 20:1 ratio should give him plenty of control over the engine's position, and if he doesn't, he probably shouldn't be handling anything more dangerous than a potato in the first place! I guess I could incorporate a small sheet metal shroud over that area.
Maybe a strategic tab or two for a locking pin? There would be a multitude of locked in work angles with a flywheel.
I just drill a bunch of holes in the tube for a drop-in lock pin- - - - -maybe every 30 degrees or so. When I'm whittling on the front or back of the block, I bolt a pivot plate to a few cylinder head bolt holes- - - -for machining the flywheel end of the block for a full circle lip seal with my Van Norman boring bar, etc.
OSHA would be proud of you for that, Jerry. LOL!
But I'm with you on keeping fingers out of where they don't belong. It doesn't take much brainpower to do that.
65+ years of tinkering with dangerous stuff with unshielded moving parts- - - -and I've still got all my fingers and toes- - - -but a few of them have some impressive scars. Maybe being "lucky" is better than "good" at times!
LOL!
Yeah, I've got a distinctive L-shaped fingerprint on my left pinky that was from helping a buddy install a Triumph sports car 4 banger engine without a hoist. Seems that finger was in the wrong place as we set it in.
I eyeballed Stewarts engine stand real close-like. He left without it. I pondered about taking it home with me, but heck, Stewart's too nice of a guy to do that to... smile
Besides that, the cops pulled me over for sightseeing on the 301 bridge on my way home and I never would have gotten away with it.
24601
Carl ... As I still have, essentially, Stewart's engine stand in my "control" ... I could let you have it for a nominal gratuity .... to quote Pooh Bah, "For a very low figure ..." smile
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
Hey John: How about a picture or two for those of us that couldn't make it to Wrenchfest?
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Task Force Truck
Follow in the DITY Gallery
1959 3200 Task Force
The Ballad of Enkidu
That stand is a Harbor Freight product- - - -and while it's a bit pricey ($300.00 or so) it looks to be very good quality and is capable of handling the weight and length of a stovebolt six safely. It's even got four leveling jackscrews to make sure the stand doesn't roll all over the shop while you're torquing cylinder head bolts or main bearings. And it folds up into a very compact package for storage when not in use. If you think that's expensive- - - -check out the doctor's labor rates at your local emergency room after an engine stand tips over and mashes a foot!
www.harborfreight.com/automotive/li...-driven-rotating-engine-stand-57745.html
DAYTONA 1500 lb. Capacity Gear-Driven Rotating Engine Stand
I would like to stick MY 25000 CENTS in, whether anybody likes it or not; since the stand was put together the night before Wrenchfest, I was kinda hoping to be the 1st to use it. But since MY engine is in Tennessee right now, IF somebody REALLY needs to BORROW it, I GUESS I wouldn't mind. But it has to be back in my garage when my engine gets back home. And thank you for thinking I'm a NICE GUY! Plus, if our "Chief Bottle Washer" collects any monetary contribution, it best be put into the ODSS fund.
But SERIOUSLY guys, YOU FOLKS are the NICE ONES and I CAN'T THANK ALL OF YOU ENOUGH!!!!
S2
Stewart2
1955.1 3100
Both Owner and P/U have lots of miles, lots of history and need LOTS of TLC
Jack of several trades and experiences; Master of none
Authorized Pest
Authorized Pest
Originally Posted by Fibonachu
... How about a picture or two for those of us that couldn't make it to Wrenchfest?
Here's the one HRL mentioned above. The pictures from WF show more engine than engine stand. wink
DAYTONA 1500 lb. Capacity Gear-Driven Rotating Engine Stand - pix from Harbor Freight
~ Peggy M
1949 Chevrolet 3804
That HF engine stand has a worm gear drive...when you let go of the handle it stops right there...no chance of the handle smacking you in the arm if your hand slips off, I like that feature!
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
ODSS President
ODSS President
HHAHAHAHAHAHA!!!
~ Cosmo
1949 Chevy Half Ton
V
VEW Offline
V Offline
X2
~ Victor
1957 3100 - moved on
I like the idea! When I get around to opening up the 261 that’s just waiting to get back to work I plan to do a couple of cheap upgrades on my 40 year old engine stand. First is to widen and lengthen the wheelbase. Second is adapt a slack adjuster off an old Nabors flatbed that’s now a bridge to a gear drive for the engine stand. Should be pretty easy. If/when I do pictures will be posted.
RonR
1970 340 Duster
1964 CJ5
Moderated by  MNSmith
