1 members (60steve), 71 guests, and 4 robots.
Topics128,181
Posts1,057,152
Members48,464
I haven’t been earning my keep around here lately so thought I’d share a few pictures of what I believe is a original stock Rochester B off my ‘51 3600, 216 engine truck. It had documented 43,000 miles when purchased from a small museum back in 2013. The 261 Rochester is from a engine that was in a ‘59 wrecker. The owner pulled the good (?) 261 and installed a 327 many years ago. Bought it from his son 5 years or so ago.
Just looking, I can’t tell them apart. The easy tell is the 261 carb’s manifold mounting holes are about 1/4” wider.
Also 50 is stamped on the 261 carb.
I’ll let the pictures do the talking. The 216 Rochester has the Id tag.
RonR
1970 340 Duster
1964 CJ5
More photos, again the 216 Rochester has the ID tag.
RonR
RonR
1970 340 Duster
1964 CJ5
It is easy to tell a 261 carb, as the throat is big enough it is almost touching the power valve vacuum port.
My Blog
Dave, I see what you’re saying. When I look at image 6, the 261 carb in my opening post I see a a chamfer on the carb throat bore that's not on the 216 carb in image 7. It’s hard to see a difference in the power valve port locations. Curious.
RonR
RonR
1970 340 Duster
1964 CJ5
Moderator, Electrical Bay
Ron your images are not showing on my computer this morning but I don't think the carburetor on the 261 was the one made for that engine. At least based on what I saw last night. Somewhere I have an image of the one for the 261. Can't find it now but the bore was larger.
~ Jon
I just gave John a Rochester carb that I removed from a 261 engine, one that was used in a 1959 Chevy dump truck. The carb appeared to be the original one the truck was built with. IIRC, Rochester Bs for the 261 had a slightly larger venturi, and possibly a little bigger throttle plate than the one used on 235s. He should be posting a detailed tech tip on his evaluation of that carb soon.
