7 members (3B, 68ironhead, Jon G, 2-Ton, Phak1, 49nut, Gray_Ghost), 64 guests, and 1 robot.
Topics128,049
Posts1,055,691
#1545567 05/01/2024 11:38 PM
8
nothing beats a try but a failure
8 Offline
Did the 1954 3600 have a heater control valve? If so, how was the heat controlled from inside of the cab?
1955.1 3600 5 window 4 speed all original except the 410 gears.
In the Project Journal
87GN #1545571 05/02/2024 12:27 AM
There were a few heaters that were used but the recirculating and fresh air heater used a control valve ,ranco valve it was called.
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
Here is some pictures off the web ,the valves are hard to find but can be rebuilt there are other universal valves that may work .you would also need the control rod and knob.
"The Journey"
Follow in the DITY
They can be rebuilt as long as the expansion bulb is still intact and not damaged. Mine sadly was not and am currently developing a work-around. Will look mostly stock.
Chip
'Rusto-Mod'
'51 Chevy 3600 5 window | C4 Corvette front/rear suspension & drivetrain | everything else looks old and stock
'92 GMC Sonoma GT #15 of 806
'91 GMC Sonoma GT Extended cab 1 of 1
Trucks, Trucks.....and more Trucks
These two guys can help you if you need a new Ranco valve or a rebuild.
Rebuilder of Ranco and RobertShaw heater valves. New Ranco heater valves for sale
Joe Hudacek
6606 Banks Avenue
Superior, Wisconsin 54880
715-392-6169
Cell: 218-213-8906
http://www.heatervalves.net/
Rebuilder of Harrison and Ranco heater control valves. New valves for sale 1950 -1975
Jim Tucker
29597 Paso Robles Road
Valley Center, California 92082
760-749-3488
http://www.heatercontrolvalve.com/
1950 Chevrolet 3100 (Ol' Roy)
I bought a valve for my 47 3600 from Joe Hudacek. He took mine to rebuild. Great guy to work with. He should have what you need.
1947 3600 Chevy
87GN #1545600 05/02/2024 11:18 AM
8
8 Offline
Wow, thanks guys.
87GN #1545602 05/02/2024 12:11 PM
If you are looking for a heater there is one on Facebook market place for 90. It has the valve and knob as well but the capillary tube looks cut .
"The Journey"
Follow in the DITY
