1 members (Otto Skorzeny), 122 guests, and 3 robots.
Topics128,100
Posts1,056,510
Members48,448
#1545566 05/01/2024 11:34 PM
8
nothing beats a try but a failure
8 Offline
I have a 1954 3600. I am looking for 2 small items. #1- there was a cork seal in the front yoke of the rear shaft. #2- I am also looking for the front wheel hub bearing dust cover. Who has these parts?
1955.1 3600 5 window 4 speed all original except the 410 gears.
In the Project Journal
O Online: Content
The dust covers seem to be a strange size. I think Jim Carter or the Filling Station has them.
1950 Chevrolet 3100 (Ol' Roy)
Cannot speak to the dust cover ...
The Cork Gasket is sometimes difficult to find ... I have one, send me a PM , there are a couple on Ebay - search GM 3705197
I've attached pics of the gasket and washer that goes in front of it. I have one of the steel washers. Send me a PM , there is one on Ebay - search GM 3705196
cork gasket
steel washer
cork gasket gasket
steel washer
Ron - - Dusty53
1954 Chevy 3604
They are spicer D3A dust cap kit . Got mine from summit but could probably order through auto parts store comes with new screw on cap for 1350 series. Jim
87GN, In addition to the parts Dusty53 mentioned above, I think you said you were looking for front wheel hub bearing grease dust caps??? If so, a bit of Chevy Master Parts book searching shows the original part was listed in 1929-57 book as GM# 3680897 - Cap, wheel hub, grease 2-5/16" OD that fits 1946-57 3/4 & 1 Ton trucks. A latter book indicates that was superseded by GM# 3768604 and that lists as fitting 1946-62 3/4 & 1 Tons as well as 1963-66 C-20/30 series trucks. I couldn't find anything offered on the web for either of these GM part numbers.
However, a search for 2-5/16" OD grease hub caps came up with this Dexter 2-5/16 OD pair of hub capsthat may fit your need. There were a bunch of other similar diameter caps, but none that seemed to have the possibly needed cap height for your truck. Hope this may be of some help. wink
~ Dan
1951 Chevy 3 window 3100
