Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
1 members (lumbersawyer), 100 guests, and 1 robot.
Topics128,277
Posts1,058,453
Members48,490
#1545368 04/29/2024 10:22 PM
I am looking to use the properly sized in-line fuse...can someone tell me the AMP draw for a Guide S-16 spotlight?. I am using a GE 1323 32 CP bulb in this 6V system.
Thanks.
LUKE
Maybe 4 to 4.5 amps. Say 10 amp fuse
If my math is correct and research is correct.
You could check it with a multi meter with a 10amp fuse side if you have one .
I found this a well
Here is a 1323 bulb...
I believe that I have the information that I need...going to start with 5 amp fuse and see how that works with initial draw
Steiner's has that bulb for 8 bucks + shipping.
~~ Jethro
1954 3100
Back to Life
In the Dity Gallery
1951 3100 (gone) / 1956 4400 (still in the neighborhood) / 1957 6400 with dump body (retired) / 1959 3100 panel (in the woods junked) / 1978 Custom Deluxe K10 / 1993 S-10 4.3 / 2004 Chevy Crew Cab / 1945 John Deere H / 1952 John Deere B / 1966 John Deere 2510 / 1967 John Deere 1020
A 5 amp fuse in a circuit drawing 4 amps continuously may eventually suffer from heating enough to cause the fuse wire to "droop" and eventually fail. I'd use a 10 amp fuse. Remember, fuses are there to protect the wiring, not the device providing the load.
The 5A fuse appears to be getting the job done...I am going with it until further notice.
Thanks everyone who participated in this post.
LUKE
