Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
4 members (Steelbee, Hotrod Lincoln, Otto Skorzeny, 1955 1 Series), 129 guests, and 6 robots.
Topics128,285
Posts1,058,533
Members48,490
M Online: Content
Have any of you installed this type of rear plate holder. Traditionally the bulb is at the top but that won't work with this plate holder. The mounting bolts would be down below and behind the bumper. It seems wrong for the bulb to be at the bottom but I can't see how else to mount it. Any experience with this mount would be appreciated.
Last edited by klhansen; 04/29/2024 12:19 AM. Reason: added more info to the title
1956 3100 three speed 6 cyl. Stock with a few upgrades.
MickeyP, See the screen grab below from fellow Bolter rooney3100's 1956 3100 Gallery photos. Shows the installation location and orientation you seek. Mount bolts on the back side of the plate mounting bar go through the rear bed cross sill to secure to the truck if IIRC. wink
~ Dan
1951 Chevy 3 window 3100
Looks like the same one that came on my truck. I assume it was installed by previous owner. Not sure if he goofed on first hole or if those were for a different original bracket. There are two bolts but I took this shot blind by reaching under. Hope it helps.
1957 Chevy 3200
Daily Driver
PS, A/C, Tilt column, Rebuilt 350, Rebuilt TH350, Reupholstered Bench Seat, sound proof/insulated, LED headlights/taillights/backup lights/interior courtesy lights.
Follow in the DITY
M Online: Content
Thanks Dan and D. Appreciate the help. Better to be sure than sorry.
