1 members (SandraD), 56 guests, and 5 robots.
Topics128,021
Posts1,055,355
Members48,420
#1544853 04/23/2024 6:02 PM
I need to wire up some sort switch to activate brake lights. What would be the best way to go? Use a pressure switch in the brake line or a micro switch some how on the brake pedal? Dave
1941 Chevy
"First rebuild - complete!"
Follow the story in the DITY
1941 GMC resting peacefully
1946/1947 Chevy Street rod on s10 frame complete
1945 GMC panel truck in line for restoration
1941 Plymouth stock complete
1941 GMC COE in restoration process
Read his Project Journal
1941 Chevy Coe uncertain future resting now
homer52 #1544855 04/23/2024 6:14 PM
Either one really. But the micro or lever switch is easier to troubleshoot and replace.
homer52 #1544856 04/23/2024 6:14 PM
What year is your truck Dave
homer52 #1544861 04/23/2024 6:30 PM
H Online: Content
I'd use a T fitting in a brake line and a hydraulic switch. Simple, pretty much idiot-proof, and no adjustment required.
homer52 #1544896 04/24/2024 1:16 AM
It's for my 41 coe that will sit on a 2001 chevy 3500 cutaway van. So far things are matching up quite nice. Dave
1941 Chevy
homer52 #1544899 04/24/2024 2:20 AM
Sir Searchalot
Sir Searchalot
If I plumbed in a pressure switch it would leak. Find something that moves to trip this.
A thousand ways to use this:
Click
homer52 #1544910 04/24/2024 12:47 PM
7
7 Offline
If I were fabricating something, I would go with electro-mechanical. The switch on my '57 LCF is still working, the pressure switch on my Harley is NOT working.
homer52 #1544918 04/24/2024 2:27 PM
Moderator, Electrical Bay
It was mentioned early on, but I'd go with a micro-switch. Easy to make a mounting bracket...a small piece of angle aluminum will do it. Set it so the brake lever closes it when the brake pedal is at rest and wire it so the normally open option is taken. Cut the mounting holes oval-shaped so you'll have easy adjustment. That way when the brake pedal is pushed, the switch's internal contacts will close and the brake lights will go on. The one in the image below was made in Switzerland, is about 1 inch wide and will handle up to 5 amps at 250 volts and I've seldom had one fail in the 60+ years I've used these. Good luck.
~ Jon
homer52 #1544937 04/24/2024 4:04 PM
1941 Chevy
homer52 #1544940 04/24/2024 4:30 PM
What kind of switch was on the "2001 chevy 3500 cutaway van"? Does it still exist?
homer52 #1545007 04/25/2024 1:35 AM
I don't know what was there, guessing it was a micro switch.
1941 Chevy
homer52 #1545008 04/25/2024 1:46 AM
Are you using the stock brake pedal and setup from van or something custom? Can you post a picture of your brake pedal setup
homer52 #1545009 04/25/2024 1:50 AM
It would have had this type of switch on brake pedal
homer52 #1545010 04/25/2024 1:58 AM
Sir Searchalot
Sir Searchalot
We keep throwing this term "micro switch" around. They are not the correct switch for a 1941 COE restomod on a 2001 9900 GVW Van. If the van or the van column has a switch, that would be OK. If not, Use something like I posted. The one I have linked was used on many older trucks and works just fine. Already has a mounting bracket and uses two bullet terminals. Just mount the era correct Chevy switch where the pedal arm or brake linkage will activate. Bend the arm if necessary. Add a "trip" bracket, bolt, post/feature.... on the pedal or brake linkage if necessary. It is a normally closed switch.
Some micro switches are not suitable for outside of cab, hard to mount, may need to solder wires to it....no good. Too yuppie.
THISis an example of what Jerry is talking about, that works too and may be a lot less work. Find a place on the master cylinder or it's output line. You may need a tee that has one or two flare ports. This is basically an electro-mechanical switch. So is a micro switch which we used to call a Cherry Switch. No one has suggestd anything but Electro-mechanical.
Like said, if you are still unsure/undecided, post a lot of pics of pedal, M/C and etc. so we can help figure it out.
