I’m currently finally putting my truck together. Working on the interior after getting my bench in I noticed several holes under the dash. They look to be original but not sure what they’re for. Including pictures.
On I side note I got the side trim for the bench seat. Any help with screw size to mount these?
I can't prove it, but I think some of those holes are for aligning the parts for spot welding on the assembly line. I think the two larger ones in your first pic would qualify for that. To the far left would be for the bracket for the parking brake release rod.
I think the seat skirts use #8 sheet metal screws.
Kevin 1951 Chevy 3100 work truck Follow this saga in Project Journal Photos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together.
Thanks everyone. Just making sure I wasn’t missing a brace or anything critical. I removed everything to paint and powder coat and now I just want to get it together. The extra holes from factory makes sense. Thanks again Daniel
