| | | Forums66 Topics128,102 Posts1,056,184 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2024 Posts: 126 'Bolter | | 'Bolter Joined: Mar 2024 Posts: 126 | Hello everyone I am new to the forum I hope I am entering my question in right place. I have a 1955 second series 3200 The engine numbers are, con4 J 13 0 ON THE BLOCK F1014B Next to the oil stick any help woud be great. thanks
| | | | | Joined: Apr 2004 Posts: 5,074 Authorized Pest | | Authorized Pest Joined: Apr 2004 Posts: 5,074 | Mike, you were close. We made your post its own thread since each of these are unique, so to speak. I'm sure folks will be along with the info you need. They are probably gonna ask for some images, as you may have seen in other ID questions.
~ Peggy M 1949 Chevrolet 3804"Charlie" - The Stovebolt FlagshipIn the Gallery"We make a living by what we get; we make a life by what we give." -- Winston Churchill | | | | | Joined: Mar 2021 Posts: 430 'Bolter | | 'Bolter Joined: Mar 2021 Posts: 430 | mikeg1955 those ID don't seem complete for the 55 year or others around it. Can you post a picture of the ID and where they are located to get a better visual. This link will help you decode yourself until the history buffs arrive https://chevy.oldcarmanualproject.com/models/engine.htmI good news for you is I have a 1956 3200 and I am straight down US 23 from you near suwanee. | | | | | Joined: Oct 2021 Posts: 6,805 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,805 | I used to live on US 23 in Atlanta. I'm 5 miles away from my old place now.
1950 Chevrolet 3100 (Ol' Roy)
| | | | | Joined: Mar 2021 Posts: 430 'Bolter | | 'Bolter Joined: Mar 2021 Posts: 430 | F1014B. Made in flint on oct 14. B automatic trans in 3100-3200 models
Should be serial number nearby
| | | | | Joined: Mar 2021 Posts: 430 'Bolter | | 'Bolter Joined: Mar 2021 Posts: 430 | The more I look at it. It could be the 8 cylinder with the B if it’s so is that a 6 cylinder or a 8?
With that half year second series going into 1956 It could be a later casting. More details from your truck please | | | | | Joined: Mar 2024 Posts: 126 'Bolter | | 'Bolter Joined: Mar 2024 Posts: 126 | my serrial # 3769716 and my head number is 3836848 with GM 16 below it I beliieve the engine was replaced since it a 1960. thanks for your help
| | | | | Joined: Mar 2024 Posts: 126 'Bolter | | 'Bolter Joined: Mar 2024 Posts: 126 | It is a 235 inline 6 serial number 3769716 on the block. The head number is 3836848 with GM 16 below the number. thank you
| | | | | Joined: Feb 2004 Posts: 29,799 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,799 | There should be a stamped (not cast) letter/number combination on a machined pad immediately behind the distributor. Decoding that information should give you a good indication of the original year of manufacture and the vehicle the engine came from. Jerry
| | | | | Joined: Mar 2024 Posts: 126 'Bolter | | 'Bolter Joined: Mar 2024 Posts: 126 | F1014B is stamped numbers and letter. 235 inline 6 serial number 3769716 on the block. The head number is 3836848 with GM 16 below the number. thank you Jerry
| | | | | Joined: Sep 2009 Posts: 5,878 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 5,878 | Mike, The block casting# 3769716 decodes as a 1958-62 235. The head casting# 3836848 decodes as for a 1956-62 235. Your Serial# F1014B decodes as:
F = Flint manufacturing plant
10 = October (10th month)
14 = 14th day of October
B = 1960 passenger car 235 equipped with a Powerglide transmission originally (may have a hydraulic cam/lifters)
Not unusual to find a passenger car engine migrating to a truck. If you can provide the casting date codes, found behind the starter on the side of the block, that can provide a bit more confirmation info.
~ Dan 1951 Chevy 3 window 3100Follow this story in the DITY Gallery"My Grandpa Carl's Truck and How it Became Mine"1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
| | | | | Joined: Mar 2024 Posts: 126 'Bolter | | 'Bolter Joined: Mar 2024 Posts: 126 | con4 J 13 0. thank you Dan
| | | | | Joined: Sep 2009 Posts: 5,878 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 5,878 | con4 = Conveyor # 4 on the assembly line. J = October 13 = 13th day of October 0 = 1960 Most welcome Mike!
| | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | The "B" in your engine code (it's not a serial number, that ended in 1956) was used from 1957 through 1962 in Passenger cars with the Powerglide transmission. It's very strange that your block was cast on October 13th and machined and built on October 14th. The only way this would make sense to me is if in 1960 they skipped the letter I (eye) in the casting process making J actually September. Mike B  | | | | | Joined: Apr 2004 Posts: 5,074 Authorized Pest | | Authorized Pest Joined: Apr 2004 Posts: 5,074 | You know mikeg1955, if you can get a pix of some of this spots so we can tell better. I've seen a few times in here where the Stovebolt Collective uncovers stuff that made more sense to them. See if you can get a pix of these numbers.
